Starting battery
Old Dec 4, 2023 | 08:57 PM
Devanwon's Avatar
Devanwon is infamous around these parts
Starting battery
Wanting to replace my starting battery, (right side one) as mine seems the wrong size by previous owner. Can someone let me know what it should be and do I need to do anything special like on vcds or anything once I change it or will the car not need anything that way. Thanks guys!
Old Dec 5, 2023 | 09:16 AM
1eapplebaum's Avatar
5 Year Member
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
https://drive.google.com/file/d/1HPvY6LutXbujrQ5LeAxa4JvBT39g1_6-/view?usp=drivesdk
The battery procedure above. The starter battery is AGM type. The size you will have to look up since I don’t recall. My B is in hibernation . Plug and play no adaptation required
Old Dec 5, 2023 | 08:53 PM
Devanwon's Avatar
the link doesn’t go to anything, maybe another link ?
Old Dec 6, 2023 | 12:42 AM
5 Year Member
connecting and connecting batteries-------------------------------------------------------------------------------------------------Procedure for disconnecting batteriesThis procedure must be strictly followed.1. Switch off ignition and all electrical consumers and remove ignition key.2. Wait 60 seconds - Disconnect starter battery in luggage compartment on right (see below).3. Disconnect main system battery in luggage compartment on left (see below).Caution:If the sequence is not followed, the pyrotechnical battery isolator may be triggered and the electrical equipment in the vehicledamaged.The battery isolation igniter for Continental GT and Continental Flying Spur is shown on the left hand side, and for Continental GTC onthe right.091501w0060-------------------------------------------------------------------------------------------------Disconnecting starter battery in luggage compartment on rightWarning:To increase crash safety, the starter battery in the luggage compartment on the right is equipped with a battery isolator. In anaccident, the air bag control module triggers a charge disconnecting the voltage supply wire to the starter.Battery isolation is performed pyrotechnically, with a very small explosive charge. To avoid accidentally triggering the charge whenworking on the battery or the battery isolator, you must always disconnect the battery earth on the negative terminal of the starterbattery first.Remove right hand luggage compartment carpet panel. (refer to bin: 0867)Continental GT and Continental Flying SpurDisconnect battery clamp (1) from battery negative terminal post.Disconnect battery clamp (2) from battery positive terminal post.091501w0005Continental GTCDisconnect the negative terminal (1) of the starter battery.Warning:On Continental GTC cars a separate positive cable (3) from the starter battery to the starter battery fusebox is fitted. This cableremains live when disconnected from the starter battery until the main battery is also disconnected. When disconnected take care notto cause a short circuit or allow the cable to come in contact with the air bag connector (7).Remove the fixing (2) and disconnect the red starter battery fusebox cable (3) from the battery near to the positive terminal.Lift up the plastic cover (4) to access the positive battery terminal, and loosen the clamping nut.Lift off the battery isolation igniter (5) and attached starter cable (6).091501w0057-------------------------------------------------------------------------------------------------Disconnecting main system battery in luggage compartment on leftDisconnect starter battery in luggage compartment on right (see above).Remove left hand luggage compartment carpet panel. (refer to bin: 0867)Disconnect battery earth lead (1) at battery negative terminal.Disconnect the battery positive cable (2) at battery positive terminal. Remove main system fusebox. (refer to bin: 0937)091501w0006-------------------------------------------------------------------------------------------------Connecting batteriesThis procedure must be strictly followed.1. Connect main system battery in luggage compartment on left.2. Connect starter battery in luggage compartment on right.Caution:If the sequence is not followed, the pyrotechnical battery isolator may be triggered and the electrical equipment in the vehicledamaged. The procedure for connecting batteries must be strictly followe
Old Dec 6, 2023 | 12:45 AM
5 Year Member
6/12/11 WT 01000 09-2011 [English] / Disconnecting and connecting batteries Page 2 (OID = <33597_4_1_1> UID = <3344> Dataset = <WT 01000 09-2011 [English]>Connecting main system battery in luggage compartment on leftThis procedure must be strictly followed1. Switch off ignition and all electrical consumers and remove ignition key.2. Fit positive terminal clamp onto battery positive terminal.3. Only after securing positive terminal clamp, fit negative terminal clamp to negative terminal on battery.Warning:On Continental GTC cars, the positive cable from the starter battery to the starter battery fusebox will be live once the main systemsbattery is connected.Installation:Tighten battery positive terminal clamp securing bolt.Tighten securing bolt of battery negative terminal. (refer to table: torq_091501_by614_01)Caution:Battery terminal clamps must only be fitted by hand without force, this prevents damage to battery housing. (Do not use mallet orhammer).Battery terminals must not be greased.-------------------------------------------------------------------------------------------------Connecting starter battery in luggage compartment on right1. First switch off ignition and all electrical consumers and remove ignition key.2. Connect battery in luggage compartment on left. (refer to bin: 0915)3. Fit positive terminal clamp onto battery positive terminal and the cable to the starter battery fusebox on Continental GTC cars.4. Only after securing positive terminal clamp, fit negative terminal clamp to negative terminal on battery.Installation:Tighten battery positive terminal clamp securing bolt.Tighten battery negative terminal clamp securing bolt. (refer to table: torq_091501_by614_01)Caution:Battery terminal clamps must only be fitted by hand without force, this prevents damage to battery housing.Battery terminals must not be greased.-------------------------------------------------------------------------------------------------Steps after connecting batteries1. Switch Ignition on and off again with ignition key - Read fault memory.2. Perform Guided functions/Component replacement using VAS 5052. Read, interrogate and clead fault codes. (refer to bin: 0909)3. Initialise Electric windows. Refer to side glass - To initialise. (refer to bin: 0845)4. Initialise sunroof (if fitted). (refer to bin: 0877)5a.(2 door cars) Initialise front seats. (refer to bin: 0881)5b.(4 door cars) Check seat memories have been retained. Reinitialise individual seats as necessary.- Front seats (refer to bin: 0881)- Rear seats (refer to bin: 0885)6. Perform zero calibration on steering angle sensor using [VAS 5052], Refer to Diagnostic system - Guided functions. (refer to bin:0909)7. Check all electrical consumers are functioning correctly.
Apparently the link required permissions from each user. So this should help....screen shots.
Old Dec 6, 2023 | 05:50 AM
5 Year Member
Amendment to above. Apologies!
Warning:
battery first.
091501w0005
Continental GTC
Warning:
091501w0057
091501w000
Old Dec 6, 2023 | 06:12 AM
xclens's Avatar
5 Year Member
xclens is infamous around these parts
"Battery isolation is performed pyrotechnically, with a very small explosive charge."
I've never heard of such a thing. Is this a standard for all Bentley models / years?
Excited owner
Bentley
Jan 26, 2022 06:54 AM
NikitaUCLA
Feb 18, 2020 10:45 AM
AwesomeBMW
Mar 9, 2013 12:19 PM
Pistol
Mar 15, 2004 06:50 AM
jcramair1
Sep 22, 2003 03:13 PM
