No ignition power first start of the day
Old Jun 22, 2024 | 06:03 PM
AndyTork's Avatar
AndyTork
I have a strange issue on my 2006 Flying Spur (Australian Delivered, RHD)
Only had the car a few weeks appeared fine a couple of weeks ago, however recently when I get in the car first thing in the morning it just doesn't like to go into "ignition mode", what would be considered position 2 on a normal car I guess, what I mean is that in acc position everything works, but I don't get any of the normal cluster lights / messages "press brake" etc when turning ignition. Note : the temperate has dropped here somewhat in the last few weeks
I just replaced both batteries thinking this could be related and not knowing the battery history, so know these are good
if I leave the key in the car and leave it alone it all comes good after a few minutes (5 - 15 minutes) after its started once I have never seen it happen on the same day again
When this occurs I get the following codes,-
01314 - Engine Control Module
004 - No Signal/Communication
01315 - Transmission Control Module
01299 - Diagnostic Interface for Data Bus (J533)
013 - Check DTC memory
01321 - Control Module for Airbags (J234)
And this one
001672 - ECM Power Relay Load Circuit
P0688 - 004 - Open Circuit
Once started and cleared, they don't come back until the next day when I try and start it
Should I start with the ECM relay ? Could it be going weak / sticky ? Is it just the - J271 - Motronic Engine Control Module (ECM) Power Supply Relay (167) in the right plenum fusebox, or is there more I should check / replace ?
Thanks in advance, hope someone can help. I don't have a name of an independent specialist near me at the moment, but looking for one also (Gold Coast, Australia) .
Andy
ScottUK
Bentley
Feb 9, 2022 12:28 PM
turbo_secret
Bentley
Nov 2, 2013 02:33 AM
jfondren3
Jun 29, 2013 12:00 PM
Savetheclutch
Sep 27, 2011 06:05 AM
