Bentley Gt 04-10 diy suspension conversion
Old Feb 14, 2025 | 04:34 AM
Shaqovic's Avatar
5 Year Member
Shaqovic is infamous around these parts
Hello member,
After months of tests and modifications, I found the parts needed to change from air suspension to coils.
i drive the car and its 100% better than air suspension
All the experiment was done by me alone and no sponsors involved 😂
if you need to change your front just dm me.
btw the measurements from middle to fender is adjustable according to your choice, mine is 410
parts costs $200
Old Feb 14, 2025 | 09:28 AM
Frank ( Sunnyside )'s Avatar
Frank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond repute
Originally Posted by Shaqovic
Hello member,
parts costs $200
Don't stop there. Tell us more. My time Attack car will run air for now but will eventually require springs. So I'm well interested in what you have to say
Old Feb 16, 2025 | 12:13 PM
sazam's Avatar
sazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud of
did you have module to fool the system and get rid of the error codes?
Old Feb 18, 2025 | 01:24 AM
Shaqovic's Avatar
5 Year Member
like I mentioned above, I have changed the front parts only, I kept rear air suspension and remove fuse 6 in boot fuse box to disable compressor from running.
the car is driving and handling more better than it used to and I am not waking up scared to find it on floor like before 😂
if anyone has access to a machine shop and willing to change from air to spring just contact me
Old Feb 18, 2025 | 01:30 AM
Shaqovic's Avatar
5 Year Member
unfortunately I couldn’t find it yet, I heard it’s possible with a transistor but need to find someone tried it first
I have two errors on dash now, height error cuz both front sensors broken and shock errors cuz plugs not connected
Old Feb 18, 2025 | 04:47 AM
How long have you been running it that way.
Are you aware that there is still air in the rear shocks and over time it will slowly leak. There are still components and air lines connected that could fail. It's enviable. Without a compressor the shocks will not be able to keep topped up. They won't be able to adjust to loads either.
You should really remove all air suspension or non at all. Keeping the rears air only IMHO is not a great idea!
Old Feb 18, 2025 | 10:57 AM
Shaqovic's Avatar
5 Year Member
for now it’s been a month I’m on springs, to activate the compressor it’s just a fuse # 6 in boot
so its less hassle than keeping front air and worry everyday they will drop
jtsbentleygt
Bentley
Jan 29, 2025 04:57 AM
therron4ou
Bentley
62
Mar 13, 2023 09:35 PM
blakecameron1!
Bentley
Mar 7, 2023 09:09 PM
rdsrllc
Bentley
19
Jul 1, 2015 10:35 AM
