Starter battery not charging
Old Mar 29, 2025 | 03:22 AM
DanW12's Avatar
DanW12 has much to be proud ofDanW12 has much to be proud ofDanW12 has much to be proud ofDanW12 has much to be proud ofDanW12 has much to be proud ofDanW12 has much to be proud ofDanW12 has much to be proud ofDanW12 has much to be proud of
Hi guys, just a quick one to kick off the weekend….
My starter battery doesn’t seem to be charging.
Both the starter and house batteries are brand new, proper spec Varta items, fitted about a week ago. I’ve been monitoring the voltages to chase down some electrical gremlins and I’ve noticed that the house battery charges nicely at 13.6v when idling, but the starter battery never gets above 11.9v.
I took it for a good run last night and after sitting overnight, and before any kind of activity, the house is now at 12.4v and the starter is at 11.8v.
This can’t be normal, can it? Do they not charge in parallel?
Old Mar 29, 2025 | 07:01 AM
scrinja's Avatar
scrinja has much to be proud ofscrinja has much to be proud ofscrinja has much to be proud ofscrinja has much to be proud ofscrinja has much to be proud ofscrinja has much to be proud ofscrinja has much to be proud ofscrinja has much to be proud of
Pain in the A$$
Hi i put two tricklers on both as the Bentley eats the house batterys ( Left hand side )
I did hook up one over xmas via the neg on house battery Pos on the starter that did seem to work charging both but not wanting any issues in the future i stuck two tricklers on and forgot about it ...Have not come across any cast iron remedy heres a link
https://www.6speedonline.com/forums/...entley-gt.html
Good Luck ... Will be checking to see what comes up regarding your question
Old Mar 29, 2025 | 12:03 PM
DanW12's Avatar
Yeah makes sense to have 2 trickle chargers seeing as they’re two completely different battery technologies. I currently have a Noco Genius 5 but was thinking of going for a Noco Genius 2x2 which is just two chargers in one case.
Doesn’t solve the problem though. VCDS shows loads of CAN bus no signal errors on various modules, along with a Battery Charger Defective Module at the end of the scan.
I’ve just finished a 3hr drive up to Mum’s (I’m a good boy like that) and whereas the car drove faultlessly, the same could not be said of the electronics; every so often, all audio and seat/mirror/wheel adjustment would just die, then come back on a few minutes later.
I’m about to go out and do another VCDS scan so I’ll post it up here later.
Old Mar 30, 2025 | 06:11 AM
DanW12's Avatar
Very odd. Just gone to run another scan and check voltages on the batteries, now they’re BOTH charging at 13.6v as they should..?
Anyway, result if the scan is attached. Hoping someone can offer me some pointers on this, I suspect a bad battery control unit (behind the house battery) so I’ve sourced a used one, waiting for it to arrive.
File Type: txt
Old Apr 4, 2025 | 09:20 AM
DanW12's Avatar
Think I may have resolved this issue, here
Randy V
Bentley
26
Apr 17, 2024 06:26 PM
dan_189
May 11, 2015 01:34 AM
brapp
May 15, 2014 08:28 PM
GRGx3
Jun 13, 2011 05:45 AM
michaeldantep
Apr 8, 2011 06:53 PM
