Oil level via VCDS?
Old Jun 29, 2025 | 02:50 PM
N44SRX's Avatar
N44SRX
Oil level via VCDS?
Hi,
Is it possible to check oil level via VCDS on a 2012 W12 GT?
Struggling to read the dip stick. Dont want to top oil up unnecessarily and over fill.
Thanks.
Old Jun 29, 2025 | 05:14 PM
Johnny Hotspur GT's Avatar
Administrator
Hello @N44SRX ,
I am not sure if this will work but, try accessing address 17 for the instrument cluster, then tap "Meas Blocks - 08", then input 004 for the block address, you should see as pictured, BUT, the only issue is, what is the full measurement in mm for the proper oil level, I have read that others have done a oil change therefore filling with the proper amount, then reading the mm reading to get a proper benchmark number, but those were not Bentley's...
If the reading shows, please snap some pictures to share.
Johnny
Old Jun 30, 2025 | 01:56 AM
N44SRX's Avatar
N44SRX
Thank you Johnny, I'll give it a go tomorrow.
Old Jul 9, 2025 | 09:32 AM
Administrator
​​​​​​Hello @N44SRX ,
Any luck with the reading ?
Johnny
Old Jul 14, 2025 | 01:32 PM
Namulood's Avatar
Namulood
Hi,
Thanks.
Hi,
VCDS doesn’t typically show the oil level for a 2012 W12 GT. If you're struggling with the dipstick, try cleaning it and checking the level carefully. To avoid overfilling, top up slowly and recheck.
Last edited by Johnny Hotspur GT; Jul 14, 2025 at 05:05 PM. Reason: No spamming allowed.
Ryan lafferty
Bentley
Sep 11, 2021 07:40 PM
Little Gator
Sep 18, 2020 07:01 AM
solrac6262
Apr 13, 2016 08:22 PM
smggsm
Jan 20, 2014 06:45 PM
slicky rick
Nov 4, 2013 06:00 AM
