Ross Tech faults
Old Yesterday | 05:46 PM
TeamJones1962's Avatar
Veteran: Navy
TeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud of
Ross Tech faults
Good evening,
So after letting my 06 GT sit for a few yrs (life happened) I started to sort out its issues. I will try to attach the print out from the software in hopes you all can start me in the right direction as I have googled and used up what little knowledge I have with this car. I will note the things I have done so that some these codes could be overlooked. I'M more so worried about the terminal 30 on these codes.
I just replaced my air compressor today and its still not kicking on. I hooked up my Autel PowerScan to it to shoot 12v while installed and it worked for 2 mins straight. Can didn't lift a cm. I replaced the relay and checked the 40amp and both 10 amp fuses.
I replaced the radio yrs ago so the no communication with the HVAC and audio is normal.
I fitted all of the inside, license plate, side mirrors and puddle lights with L.E.D’s.
My ABS pump was replaced so I'm guessing I have to do some type of learn process to have those codes go away. ( I need to get it to a shop so the breaks could be bled also).
Both batteries are on it's own CTEK trickle charger and despite the vacuum leak it starts up ok (Might need to put some type of gas treatment in there tho).
If for some reason the log.txt doesn't load then I'll try to get some screen captures and post them.
The bumper is off due to me needing to take the fender and headlight out to get to the ABS pump.
thanks for any and all help!!!
Side note: Has anyone heard from Adrenalinejunky as of late?
Old Today | 09:49 AM
Veteran: Navy
Cleared the faults....
Cleared the faults and did another scan.
Old Today | 10:45 AM
Johnny Hotspur GT's Avatar
Administrator
@TeamJones1962 ,
I am having an issue opening your scan txt files, working on it.
As far as @Adrenalinjunkie , his last activity was July last year, hopefully he will see this tag.
Johnny
Old Today | 11:06 AM
Administrator
@TeamJones1962
I see you dropped from 98 faults, to 34... damn.
Calling you now.
Johnny
Old Today | 01:01 PM
Veteran: Navy
@TeamJones1962
Calling you now.
Johnny
😂 Yea guess that’s what sitting will get ya! Mind you some of those are from the radio/hvac change, the bumper being off and maybe me changing all the bulbs to led’s (I’m guessing).
Thanks for the call. I’m going to dig into everything we talked about on my next off day.
ContinentalGT05
Bentley
Oct 14, 2021 06:28 AM
Abdullah37
Jul 27, 2020 05:09 AM
Tiptronicus
Nov 27, 2011 08:23 PM
03 996tt
May 5, 2011 01:28 PM
