World's first BMW DCT transmission build
Old Mar 31, 2010 | 08:48 PM
CURI0's Avatar
CURI0 Is a GOD !CURI0 Is a GOD !CURI0 Is a GOD !CURI0 Is a GOD !CURI0 Is a GOD !CURI0 Is a GOD !CURI0 Is a GOD !CURI0 Is a GOD !CURI0 Is a GOD !CURI0 Is a GOD !CURI0 Is a GOD !
Just wanted to say thanks to the 6speed sponsors that have supported My M3 thus far: Evosport and HRE. Also thanks to Divexxtreme for some advice
The time has come to announce the details of my transmission build. No one has attempted this before and there unfortunately are no off the shelf parts. Everything will have to be custom made for this application which means the build time will be around 10 weeks from this point. This thread will be updated periodically with pictures and details every step of the way. I will be providing complete documented details through the process.
Why is the transmission being built?
For one, to handle more power and for longevity. It is no secret I have abused my transmission from the moment I got the car. I have done more launches at the drag strip using launch control than... anyone really. These launches are abusive, generate tremendous heat, and shorten the lifespan. Once supercharged, the issue was expounded. At a single event in '09 I used launch control 19 times with a burnout each time which generates considerable heat. I have attended 5 such events. Additionally, I have done launches on the street. I would estimate a conservative 70-80 uses of launch control up to this point.
So the transmission is weak?
No, not at all. Actually, it took far more than anyone would have thought. At these drag events, I would also run back to back at times. Keep in mind, I bumped the launch control RPM up as high as it would go, 6200 RPM. These are 6200 RPM launches after a burnout again and again. I estimate 70-80 uses and a properly used manual clutch in comparison should be good for about 50 passes before needing to be replaced. Just to give an idea of the abuse I put it through, I needed new motor mounts a year in as the abuse in the launches took its toll. Oops
Heat also contributed to shortening the lifespan. The moment I got the supercharger completed the car was on its way to the strip, literally. No exaggeration here, supercharger was completed and the car was on its way to the Famoso drag strip. It arrived with 15 minutes to spare and no cooldown whatsoever. I'm the kind of person that didn't want to save it for another day and decided to go for it. A mistake in retrospect as after the burnout I attempted to use launch control and it overheated. There are two levels of overheats, one that shows a yellow cog on the Idrive screen and one that shows a red cog. I got the red cog which means limp mode and no power until the transmission drops back down to temp. Instead of cooling it down, I decided to try again since now only 10 minutes were left. Launch control would not engage so I just mashed the gas and this worked. No overheat, full pass, no problem, however some timer light malfunction prevented a readout. I had a chance for one last pass back to back after this and I went for it. Tried launch control, it engaged, and on the first to second shift it overheated, red cog again, event over, no clean pass and a transmission lifespan shortened.
The best bet for launching the DCT at the strip or on the street for that matter with longevity in mind is to not use launch control. I learned this the hard way. However, the best bet for best times IS to use launch control.
How much power can the DCT take?
The unit BMW uses for the M3 is the Getrag 7DCI600. They rate it up to 440 pound-feet and 9000 RPM which is actually even a bit conservative. My transmission took about this torque level without incident driving around. It is the launches and overheats which made it so the clutch packs started slipping. It never fully gave out just the clutch packs were starting to slip and it was not going to get any better especially as I strove to add more power. If launches and drag strip visits are removed from the equation, on the street with a supercharger, absolutely no issues, just like stock. One can even exceed the recommended 440 pound-foot limit if just using it on the street like a normal person. Here is an up close shot of my transmission:
Ferrari's unit for the California, the Getrag 7DCL750, is rated for up to 553 pound-feet. It is also a much larger transmission and weighs 264 pounds compared to the M3's 7DCI600's 173 pounds. The Nissan GTR's GR6 by Borg Warner in comparison is rated for up to 650 pound-feet. It also has 6 speeds vs. the Getrag units 7.
So, you abused your transmission, the clutch packs started to slip, what were you going to do?
Well, I decided to build it. I knew I was not about to stop adding power any time soon so this would have to be done sooner or later. I also knew I wanted to use launch control on the strip. I started contacting companies building transmissions for the Nissan GTR seeing if any would be capable of tackling the M3 DCT. If you can name a company, I contacted them. I tried anyone and everyone and only one company said they could do it and were excited about the challenge of doing it. That company is South Side Performance:
SSP is currently the premier Aftermarket Dual Clutch Transmission Specialist in the world. They have been doing work on the GR6 in the GTR as well as the EVO SST's. They were the only company with the capability to tackle this project. Everyone else said it was not worth it, too small of a market, or that they did not have the capability to do it. Kris @ SSP told me to bring it on and that he would do what was necessary to get this thing to perform the way I wanted it to on the drag strip where performance is proven. I like that attitude
So what has SSP done? Well, SSP builds dual clutch transmissions that can do this:
http://www.youtube.com/watch?v=bupq6GTX2iE
I will be updating you guys with information periodically as it goes
Last edited by GT3 Chuck; Apr 21, 2010 at 12:09 PM. Reason: links to non sponsor points of sale and another forum
Old Mar 31, 2010 | 09:34 PM
germeezy1's Avatar
germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !
Ok so a couple of questions, is the 7DCL750 the same DCT that BMW plans to use with the F10 M5 or do they have a stronger gearbox in mind?
If I have heard right the S63B44 that will be coming in the F10 M5 will have a ~ 500 lb ft rating which seems to be within the torque capacity of the 7DCL750.
And wow the DCT transmission does seem to be very strong. In your opinion was the issue the clutches losing their clamping forces due to power or is it a heat / wear issue due to the higher temperatures that have came about due to the launch control and being beyond the transmissions design parameters?
It seems to me like the transmission was unable to stay within its designed heat range. I wonder if an auxillary transmission cooler along with fluid cooling mods on the transmission itself would have prevent alot of the damage to the clutches that happened?
Old Mar 31, 2010 | 09:46 PM
CURI0's Avatar
The issue with the clutches was a combination of heat, torque, and abuse. I'll know more when it is cracked open this weekend.
Absolutely, trans cooler is a must. I had a custom one built but it was too late at that point.
I'm not sure exactly which transmission BMW plans to use. They have not announced it yet but I wouldn't sweat it too much. They learned a lot on the M3 DCT as this was their first go at it.
Old Apr 1, 2010 | 12:32 AM
germeezy1's Avatar
So I wonder if BMW will upgrade the cooler on later models, I am definitely subscribed to this thread as I will definitely go DCT if I make the jump to an E9x M3. I completely believe its the future of high performance!
Old Apr 1, 2010 | 01:07 AM
CURI0's Avatar
I would think they need to, they just used the manual cooler for the DCT = not cool , in more ways than one.
Old Apr 1, 2010 | 07:53 AM
DarrinB's Avatar
DarrinB is a name known to allDarrinB is a name known to allDarrinB is a name known to allDarrinB is a name known to allDarrinB is a name known to allDarrinB is a name known to all
Very excited to see the final result. Good luck!
Old Apr 1, 2010 | 10:54 AM
germeezy1's Avatar
Hmm that sounds pretty crazy, almost like the oil temp issues on the N54's without an oil cooler. Any ideas as to what trans cooler you will use? Maybe one intended for drag cars?
Old Apr 1, 2010 | 01:33 PM
CURI0's Avatar
There really aren't any drag specific trans coolers for the DCT out there. I have a custom cooler now which should be fine.
Old Apr 1, 2010 | 02:11 PM
germeezy1's Avatar
Oh I know that was just thinking you may have adapted a cooler from a different application.
Old Apr 5, 2010 | 11:15 PM
DLSJ5's Avatar
DLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond repute
Love it, I appreciate you doing this J! Best of luck with it.
cnebrask
Oct 3, 2024 08:19 PM
Jul 29, 2019 11:13 AM
Perkman87
Nov 19, 2015 05:31 PM
PelicanParts.com
BMW Vendor Classifieds
Aug 25, 2015 03:55 PM
Fabspeed Motorsport
Audi
Aug 21, 2015 11:30 AM
