Radio/nav problems on E39 M5 need help!
Old Aug 19, 2010 | 06:34 PM
AdrianM5's Avatar
AdrianM5 is a name known to allAdrianM5 is a name known to allAdrianM5 is a name known to allAdrianM5 is a name known to allAdrianM5 is a name known to allAdrianM5 is a name known to all
I own a 2002 M5. I having trouble with my stock radio/navigation unit. Radio works for about 2mins then goes silent and the nav screen never come on just flashes. my indy says need to replace nav unit in the rear of car. has anyone else had this kind of problem? if it is the nav where is best place to find a used/new one.
Adrian
Old Aug 20, 2010 | 02:31 PM
RM5's Avatar
RM5
RM5 is infamous around these parts
Check out m5board.com and also the classifieds in roundel, you have the cd based unit. You can replace it with the same or upgrade to a DVD based unit.
Old Oct 14, 2010 | 04:25 PM
stuka's Avatar
stuka is infamous around these parts
Try disconnecting the battery and let the car sit for half an hour.
If that doesn't solve it, check your BM53 for water damage.
There are two issues at hand.
The NAV screen is one thing that has nothing to do with audio.
The BM53 in the driver side compartment of the trunk is the radio system, and as I found out in my car, old taillight gasket can allow water to come in and short out the unit. It's a 600 dollar unit from the cheapest source.
cockneymike
Oct 22, 2015 06:00 PM
1gr8e39
Oct 1, 2015 04:07 PM
vogz
Sep 19, 2015 01:02 PM
nal991
Sep 11, 2015 09:05 AM
flewis763
Sep 10, 2015 01:08 PM
