Is 335i Coupe faster than Z4MC? NOOOOO!!!!!!!!!!!!
Old Jul 18, 2007 | 08:36 AM
tranquility's Avatar
tranquility is a glorious beacon of lighttranquility is a glorious beacon of lighttranquility is a glorious beacon of lighttranquility is a glorious beacon of lighttranquility is a glorious beacon of lighttranquility is a glorious beacon of light
If it's true, that's garbage! Esp since the Z4 is supposedly 54 lbs lighter and 30 more horses. I don't und. Pls explain why 335i is allegedly faster. Arrgh.
http://www.caranddriver.com/features...35i-coupe.html
http://www.caranddriver.com/features...4-m-coupe.html
Old Jul 18, 2007 | 08:44 AM
MiniDHinkle's Avatar
Because it is..i believe it.
Old Jul 18, 2007 | 10:44 AM
unvmy996's Avatar
i dont .....
Old Jul 18, 2007 | 11:07 AM
Spencer's Avatar
Spencer is infamous around these parts
Faster in a straight line, yes. Tons of torque.
Suprised they turned a faster lap time in the 335. If it makes you feel any better, that will only last about 2 laps until the 335 goes into limp mode from 300* oil temps, while the Z4M runs all day long...
Either way, I wouldn't put too much trust into mag track times....
Old Jul 18, 2007 | 11:40 AM
adybuncio's Avatar
I can believe that
Old Jul 18, 2007 | 11:48 AM
win's Avatar
win
win is infamous around these parts
Old Jul 18, 2007 | 01:44 PM
kem's Avatar
kem
kem is infamous around these parts
They attributed it to a better/more composed chassis layout. This is of course the same test that says a no-IRS having Mustang GT-500 is faster then a 997 Turbo around the track. Something is skewed here, and they had 3 drivers in that test, so maybe one of them wasn't as good and he drove the cars that did poorly.
Old Jul 18, 2007 | 04:28 PM
Gabriel's Avatar
Gabriel is infamous around these parts
Torque! There is no substitute!
Old Jul 18, 2007 | 04:47 PM
20C4S's Avatar
have u seen the videos that were posted in the 997 forum? a modded 335 coupe beats a 997 then the 335 got beat by a M coupe, if u're talking about straight line.
if u've driven the M coupe then u'll realized it's not a easy car to push to the edge. it required some getting-used-to. little car's got personality which i think 335 is a lot easier to drive fast.
Old Jul 18, 2007 | 08:30 PM
Chaseme's Avatar
Chaseme is infamous around these parts
Well said.
This has been discussed on other Z4 forums and people all agree, the C&D test was a bunch of bunk.
The M Coupe is much more than 50some pounds lighter (it is closer to 300lbs, unless the 335 had very few options even then it is pushing it).
It is also noted in the Z4M community that the S54 needs a few thousand miles (even past the break in period) to get broken in and start producing all the power.
The article also complained about the M Coupe understeering. That statement is also completely idiotic and shows how the drivers don't know how to drive with a style to fit the different cars. You can't drive each car the same way.
Trust me, I have driven the 335 coupe and it's a wonderful car, much better car than the M Coupe if you wanted a daily driver. But as Spencer said, it wouldn't last long if you wanted to track it. The M Coupe is far superior if that is what you wanted (and more fun).
For a more in depth read on my review comparing the 335i to the E46 M3 click here:
http://www.m3forum.net/m3forum/showthread.php?t=137955
Old Jul 18, 2007 | 09:19 PM
Jem335i's Avatar
Jem335i is infamous around these parts
I attribute their results, like others, to their inability to drive the M Coupe properly. The 335i is the one with the understeer in my experience, but that is easily dialed out with coilvers, sways and a good corner balance.
I wouldn't be as quick to dismiss the 335 at the track as some have been, however. I've tracked mine (A++ will do again!!!) and it held up quite well, temps never went above normal operating levels.
Old Jul 18, 2007 | 09:37 PM
Well, whichever is actually faster, I hate it that both cars are so close in performance. Doesn't seem right that a dedicated sportscar (Z4) needs to worry about a DD breathing down its neck from the same manufacturer.
Old Jul 19, 2007 | 12:19 AM
StephenTi's Avatar
StephenTi is infamous around these parts
With the AMG 63/65's and M5's out there... your screwed no matter what if you're really worried about DDs breathing your neck!
Anyway, despite the close performance numbers, one drive in the MZ4 and 3-series, and you'll know which is right for you. Numbers are only a part of the equation...
Feelgood MD
Mar 24, 2016 09:35 AM
vlocci
Nov 9, 2015 09:42 AM
ECS Tuning - BMW
Sep 16, 2015 03:02 PM
Velgen
BMW //M
Sep 10, 2015 01:12 PM
plenum
Sep 2, 2015 09:16 AM
