D/A e46 M3 Supercharger Build
Old Aug 11, 2007 | 10:02 PM
wizegi's Avatar
Out of Control
wizegi is infamous around these parts
Well .. It has been about a year and a half now as we have built up my e46 M3. I figured as we come close to completion maybe I should bring everyone up to speed
Here are a few shots of the work thus far. If you goto the link below, you can follow the entire build.
Head w/Custom Cams:
Moton Suspension:
SS Stepped Exhaust:
Brembo GTRs
Vortech T1-Blower (Test Fitting)
Old Aug 11, 2007 | 10:03 PM
wizegi's Avatar
Out of Control
Here is the radiator stuffed into the engine bay
wizegi's Avatar
Out of Control
Here the rear Moton Canisters are fitted in the trunk with that OEM flare that I have come to love from D/A
Old Aug 11, 2007 | 10:04 PM
wizegi's Avatar
Out of Control
Front Moton install:
Well .. We have a mounted Heat Exchanger
Old Aug 11, 2007 | 10:05 PM
wizegi's Avatar
Out of Control
Here is the Carbon Fiber Intake Tube:
This picture below shows the ID difference between the typical Vortech S trim versus this gal's T trim supercharger inlet
Looks like we are 4 weeks out .. and look .. there is more -->
wizegi's Avatar
Out of Control
As if the CF inlet plumbing wasnt enought for today .. we have a bit more
Originally Posted by D/A
As with most motor-heads we like “HOT” gal's and consider our cars as one. The thing that we do not want is uncontrolled extreme heat within her engine bay as such we created a custom Halon fire suppression system for this project. The pictures below will show the process as it is unfolding. We are now in the exciting final assemble stage with this gal which is the time that all of the cool twist and tweaks are able to be installed. The Halon system will react automatically if the need is detected and leaves no residual throughout the engine bay such as conventional fire extinguishers do.
Here is the custom machined bracket designed to properly locate and secure the automatic fire suppression systems discharge nozzle
Here the custom machined bracket and the automatic fire suppression discharge nozzle have been set into position so that the final hose length and placement can be determined
Here is the link to the entire process:
http://www.discovery-automotive.com/...Content&id=126
Let me know what you think.
Old Aug 11, 2007 | 10:11 PM
eMJay1133's Avatar
eMJay1133 is infamous around these partseMJay1133 is infamous around these parts
I like.....
Old Aug 11, 2007 | 10:17 PM
wizegi's Avatar
Out of Control
Originally Posted by eMJay1133
I like.....
Love the avatar
Old Aug 11, 2007 | 11:44 PM
iLLM3's Avatar
Carmen I always admired your taste in modifications, wish you the best with the completion of your buildup, good luck
Martin
Old Aug 11, 2007 | 11:55 PM
eMJay1133's Avatar
Originally Posted by wizegi
Love the avatar
Thankyouverymuch
Old Aug 12, 2007 | 08:45 AM
wizegi's Avatar
Out of Control
Martin
Thanks Martin. Your garage is looking as amazing as ever :thumbsup:
SHe is coming along and now that we are at the end, I fgured I would post it up here.
Soon we will have some videos and dynos .. woohoo
Old Aug 12, 2007 | 09:30 AM
lax01's Avatar
lax01 is infamous around these parts
damn
nice build-up...whats the purpose behind this? Just to see if you can do it?
Old Aug 12, 2007 | 01:49 PM
wizegi's Avatar
Out of Control
Originally Posted by lax01
damn
Funny enough, and as with most labors of love, she never started out to be this involved.
To be honest, this project was just supposed to be a bolt on supercharger with a D/A aftercooler and Tune.
Thats it.
My relationship goes back a ways with D/A as I was the first to run thier "Race" software as it was developement originally for my car before it was decided that they should expand and market it to everyone.
That being said, when I decided I finally needed more power and wanted to go down the F/I road I called Bill (Shadowman) and after a few long talks we decided that I should send the car to them in Cali to have them design and build me a nice Supercahrger setup like that found on the M5s.
So, in Febuary 06 the car arrives in Cali and the project begins.
As we progressed and discussed what I wanted more and more got added to the build.
It went from a bolt on assembly, to a fully built top end. Custom made radiators and aftercooler assembly that is so overbuilt. (Wish I could show the aftercooelr pics, but I am told not yet )
My CSL headers where switched our for the Full SS Stepped Race assembly while adding cats back in. (Both tie into a Kreis-sieg muffler in the rear... I love that exhaust)
Then my Ground Control AD Race setup wasn't enough. I wanted Motons. So the suspension was upgraded further.
Now that I had a new suspension, my Alcons where looking old , so in comes the Brembo GTRs.
Now the power goal seems to have been settled on, "What is the most we can get on stock compression reliably"
To answer that, we are looking in tha area of 500-550whp on 93 pump gas. No N20, No Race fuel.
Sorry for the long post, but I felt you needed a little background as to how we ended up here.
Old Aug 12, 2007 | 02:13 PM
lax01's Avatar
wow...thats a good chunk of change to be spent on this car
Old Aug 12, 2007 | 02:18 PM
wizegi's Avatar
Out of Control
as i said .. a labor a love
