Used Milltek High Flow Cat Headers - $1000
Old Aug 16, 2010 | 06:01 PM
vividracing's Avatar
We have a set of used Milltek headers. They have high flow cats and about 5000 miles on them in good condition. They fit all 987 Generation 1 Boxster or Cayman.
$1000 takes them.
Old Aug 22, 2010 | 08:02 AM
crazymikie's Avatar
crazymikie is infamous around these parts
Will these mate up to a stock exhaust?
Thanks!
Old Aug 23, 2010 | 11:01 AM
Yes they fit with the factory exhaust or aftermarket.
Old Aug 23, 2010 | 11:32 AM
crazymikie's Avatar
If I was planning on leaving the stock cat back, do you think I'd get more of a gain from catless headers as opposed to these? I know I'll get a CEL, but I can get that flashed out.
Also, are these the 100-cell or 200-cell cats?
Thanks!
Mike
Old Aug 23, 2010 | 11:45 AM
You will get more power and better throttle response because you are reducing restriction. Since you have your secondary and these high flow primary cats, you will most likely not have a cel.
Old Aug 23, 2010 | 12:10 PM
lithium1330's Avatar
lithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud of
Thanks!
Mike
MA does sniffer reading/tests for vehicle emission... Unless your car is not registered/off-road use, you may want to double check to make the catless won't cause test to fail, even if you run secondary cats.
Old Aug 23, 2010 | 12:39 PM
crazymikie's Avatar
MA doesn't do sniffer tests at all anymore. Up until last year only 94 and earlier (pre-OBD2) cars would have to go on the rollers. As long as you don't have a CEL, you are good to go.
Old Aug 23, 2010 | 12:46 PM
You should be fine with not having a cell. If you want them, let me know.
Old Aug 24, 2010 | 07:09 PM
balpo's Avatar
balpo is infamous around these parts
Are these generation 1 or generation 2 from Miltek? I know these are for gen 1 987, the question is are these the revised cat or the original?
Old Aug 24, 2010 | 08:07 PM
revised... i know for a fact
COBB Tuning
Jan 1, 2025 09:02 AM
Jun 10, 2017 07:45 PM
The Oss
Aug 24, 2015 08:19 PM
ModBargains
Aug 20, 2015 12:28 PM
oddjob142
Aug 19, 2015 12:27 PM
