Oil change intervals?
Old Jul 2, 2008 | 06:05 PM
lucky_topher's Avatar
lucky_topher has a brilliant futurelucky_topher has a brilliant futurelucky_topher has a brilliant futurelucky_topher has a brilliant futurelucky_topher has a brilliant futurelucky_topher has a brilliant futurelucky_topher has a brilliant futurelucky_topher has a brilliant futurelucky_topher has a brilliant futurelucky_topher has a brilliant futurelucky_topher has a brilliant future
when i bought my boxster, it had JUST turned 30k miles and they had done an oil change on it... well, i've now since put 6500 miles on it and was double checking my maintenance info because i had thought i read 7500 miles between changes... well i get online and find that it's 15,000 between oil changes?! is that right?! the car is pre-certified and i want to take teh best care of it (without doing unnecessary things) and of course want my warranty to be in tact... so 15k miles between changes is correct?
Old Jul 2, 2008 | 06:55 PM
Crazed1's Avatar
Crazed1 is infamous around these parts
For the 2007 Boxster S, it's 20K miles. I don't put anywhere near that many miles on in a year, so I get mine changed every spring.
Old Jul 2, 2008 | 07:56 PM
boxtaboy's Avatar
boxtaboy has much to be proud ofboxtaboy has much to be proud ofboxtaboy has much to be proud ofboxtaboy has much to be proud ofboxtaboy has much to be proud ofboxtaboy has much to be proud ofboxtaboy has much to be proud ofboxtaboy has much to be proud of
For the 986 Boxster, the interval initially was 15K, but they then backed it off to 12K. 05-07 Boxsters had intervals of 20K, but in 08, they moved it back to 12K as well.
Maintenance intervals:
http://www.porsche.com/filestore.asp...letype=default
Old Jul 2, 2008 | 08:06 PM
thanks... i looked on porsche's site but couldn't find that... i was looking from something official from them...the owners manual says 15k for my 01, but that sheet says 12k or 2 yrs... i'll go by the 12k just to be safe warranty-wise and all
Old Jul 7, 2008 | 12:26 PM
Bob Z.'s Avatar
Bob Z. is just really niceBob Z. is just really niceBob Z. is just really niceBob Z. is just really nice
Just be sure to do it at least once a year, or 10k miles if you drive more than that in a year.
Old Jul 9, 2008 | 03:43 PM
Mikli's Avatar
Mikli is a splendid one to beholdMikli is a splendid one to beholdMikli is a splendid one to beholdMikli is a splendid one to beholdMikli is a splendid one to beholdMikli is a splendid one to beholdMikli is a splendid one to behold
Great info, Thanks!
Old Jul 10, 2008 | 05:37 AM
Bob Z.'s Avatar
Keep in mind that while the oil may last 10-12k miles (or longer), the filter may not so always use a high quality filter.
Old Jul 10, 2008 | 10:55 AM
Mikli's Avatar
Do you mean the factory Porsche filter or aftermarkets ones?
Old Jul 10, 2008 | 11:11 AM
Bob Z.'s Avatar
I use Mobil 1 oil filters, which are highly rated and besides, Porsche uses Mobil 1 oil as the factory fill so I figure I cannot go wrong. I even use Mobil 1 filters on my motorcycle (Honda Super Blackbird). However, I am not sure who makes the factory filter although I bet it is a top name maker. Regardless, oil will hold up longer that the filter and needless to say, one should always change the filter when changing the oil.
Old Jul 10, 2008 | 05:32 PM
Mikli's Avatar
Hum... I am planning to change the oil every 5000 (when I get there) and the oil filter every 10000. What do you guys think?
Old Jul 11, 2008 | 05:43 AM
Bob Z.'s Avatar
It seems most people have their own thoughts on when to change oil, what kind to use, etc. But I think you'll be ok with your plan; however, if you are just driving on the street I'd just do it all every 10k miles, or 1 year, whichever comes first, and skip the 5k change.
Old Jul 11, 2008 | 10:19 AM
gdmboxster's Avatar
gdmboxster is infamous around these parts
It seems oil change every 7500-10,000 miles is adequate ( depending on your driving of course ). But definitely change the filter everytime you change the oil.
Old Jul 13, 2008 | 01:05 PM
'ringmeister's Avatar
'ringmeister is infamous around these parts
if you are tracking probably twice a year is adequate
Old Jul 13, 2008 | 10:57 PM
Mikli's Avatar
I'm a fan of the PCA DEs!
Old Jul 13, 2008 | 11:47 PM
Mikli's Avatar
Can anyone confirm if these tools will work for the 987 and if they are necessary? Sorry for a newbie question. I'm planning to do my first change after the DE at the end of the month.
http://cgi.ebay.com/ebaymotors/Oil-W...spagenameZWDVW
http://cgi.ebay.com/ebaymotors/Drain...mZ170237710924
