boxster s problems
Old Aug 10, 2008 | 03:23 PM
Paully28's Avatar
Paully28 is infamous around these parts
boxster s problems
Hi,
not sure if this is the correct thread, however I have problems with my 2001 Boxster S. I struggle intermittently to put it into 2nd gear, as there is sometimes a crunch, and it pops out of 2nd. i have, at times, found it easier to go from 1st to 3rd to stop this problem, but as you can understand, this cannot continue.
Anyone else having this problem, and what can be done about it?
thanks in advance
Paully28
Old Aug 10, 2008 | 08:12 PM
Control It's Avatar
Administrator
Control It Is a GOD !Control It Is a GOD !Control It Is a GOD !Control It Is a GOD !Control It Is a GOD !Control It Is a GOD !Control It Is a GOD !Control It Is a GOD !Control It Is a GOD !Control It Is a GOD !Control It Is a GOD !
I moved the thread here. Sorry you are having problems with your boxster...hope you get some help here.
Good luck!
Old Aug 12, 2008 | 12:24 PM
David9962000's Avatar
David9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond repute
Have you been to a Porsche dealer?
Old Aug 12, 2008 | 02:55 PM
Crazed1's Avatar
Crazed1 is infamous around these parts
I'm no expert, but it sounds like syncro issue and/or shift linkage...sounds like a trip to the shop is warranted.
Old Aug 12, 2008 | 09:06 PM
mario_52's Avatar
mario_52 is infamous around these parts
Gearbox woes
Hi...Sorry to hear about your problem. I have had the exact same scenario,
sometimes it goes into second no problem- and then it would kinda go in, and then pop out, i visited the porsche dealer, and after road testing, it was decided to drop the engine/ box. a new porsche rebuilt tranny was fitted, they concluded that to strip the box and do a rebuild with the 'expensive' porsche parts was going to cost more !!!
Hope this helps..
Old Aug 12, 2008 | 10:24 PM
Bruinbro's Avatar
Bruinbro is a jewel in the roughBruinbro is a jewel in the roughBruinbro is a jewel in the rough
Anything change in the shifter linkage? If it gets out of "proper alignment" you will experience difficulty in engaging the gear and it will pop out of engagement since it wasn't fully engaged to begin with. Typical problem for those that replace the factory shifter with a SSK and don't adjust the setup correctly.
Bro
Old Oct 29, 2008 | 09:14 PM
josh@iautohaus's Avatar
josh@iautohaus is a jewel in the roughjosh@iautohaus is a jewel in the roughjosh@iautohaus is a jewel in the rough
On the trans there are clips that come loose and can cause different issues. I would check there first. The clips are right on the side of the trans and they hold the shift cables there should be two there.
Old Oct 30, 2008 | 12:00 PM
Erik @ Carquip's Avatar
Erik @ Carquip is infamous around these parts
This is very common and is something that we can help you with if you would like.
These are not the easiest gearboxes to work on so be selective as to who you trust to do this work, but I would be happy to help if you want to give me a call.
Hope this helps,
Old Oct 30, 2008 | 12:11 PM
boxtaboy's Avatar
boxtaboy has much to be proud ofboxtaboy has much to be proud ofboxtaboy has much to be proud ofboxtaboy has much to be proud ofboxtaboy has much to be proud ofboxtaboy has much to be proud ofboxtaboy has much to be proud ofboxtaboy has much to be proud of
Hope this helps,
Erik Johnson
Carquip Sales
(303) 443-1343 ext 2 work
(720) 980-9407 cell
Looks like he lives in England. He'd have to drive pretty far to get it to your shop.
Old Oct 30, 2008 | 12:14 PM
HEhehehe,
I should have realized that.
You can always send it to me if you like, we send stuff out all the time. Kind of pricey though.
Erik
Old Oct 30, 2008 | 02:13 PM
Dino V's Avatar
I have heard about this issue with a few Porsches.
Old Oct 30, 2008 | 07:14 PM
Cajundaddy's Avatar
Cajundaddy is infamous around these parts
Sounds like worn synchros/new tranny. Seek a trusted Porsche mechanic near you and have them evaluate it to find or rule out a simple fix.
Socalsporty
Sep 9, 2015 10:07 AM
arhim22
Sep 7, 2015 08:49 PM
the997dude
Sep 2, 2015 08:51 PM
