Battery keeps draning
Old Mar 16, 2009 | 01:19 PM
scottfromnapa's Avatar
scottfromnapa is infamous around these parts
I have a 2000 boxster s that I keep at a vacation home and I dont have access to electrical for a trickle charger. I have found a battery disconnect that goes on the battery terminal, will this keep the radio codes, etc in place. Has anyone used this? thanks in advance
Old Mar 16, 2009 | 10:00 PM
Max77's Avatar
Max77 has a spectacular aura aboutMax77 has a spectacular aura about
If you disconnect the battery, it will not save the radio code. For Winter storage without a trickle charger, you'll just have to input the code again each season. Is it possible to run an extension cord so you can use a trickle charger?
Old Mar 17, 2009 | 06:21 PM
Mrledzeppelin's Avatar
Mrledzeppelin is infamous around these partsMrledzeppelin is infamous around these parts
A trickle charger is the best option. No shut off switch will save the radio code and so on. I would recommend simply disconnecting your battery. I've see the cheap shut off switches go open circuit when driving and doing weird (bad) sh*t to cars.
Old Mar 20, 2009 | 01:54 AM
986S's Avatar
986S is infamous around these parts
I've definitely heard of some plug-in that saves the information. Not sure who makes it but I know it exists.
Old Mar 20, 2009 | 08:36 PM
umwolverine's Avatar
umwolverine is infamous around these partsumwolverine is infamous around these parts
You're probably doing this already, but my Porsche tech said that if you lock the car, the battery drain drops significantly.
adnanm3
Oct 25, 2016 08:38 AM
airbusdrvr
Dec 27, 2015 07:43 PM
WheelsupZR1
Oct 20, 2015 08:36 PM
G ///Mcgregor K
Sep 30, 2015 01:46 PM
