Cayman bumper removal & GT3 grill install
Old Apr 25, 2009 | 10:17 PM
porsched4ed's Avatar
porsched4ed has much to be proud ofporsched4ed has much to be proud ofporsched4ed has much to be proud ofporsched4ed has much to be proud ofporsched4ed has much to be proud ofporsched4ed has much to be proud ofporsched4ed has much to be proud ofporsched4ed has much to be proud ofporsched4ed has much to be proud of
Difficulty scale from 1 to 10: 5 (to remove bumper)
Tools needed:
-jackstands or ramps
-1/4 socket wrench
-7" extension
-T30 socket
-T25 socket
-5mm deep socket
-flathead screwdriver
-needlenose pliers
Start off by putting you car on ramps,
Pull the plastic up they are held down with hard velcro.
once you pull it up there are 3 T30 screws, remove them.
Now lets go to the bottom, there are a few more T30 screws under that need to come out. You will see them along the painted lower part of the bumper.
one of them are in a larger hole at the end of the lip.
dont forget to remove that one
now there is one in the back that is a T25 remove that as well. not sure why they made this one a different size.
in the wheel well there are 4 more T25 screws to remove.
2 up high and 2 down low
I used the socket wrench to get to these, didnt have to remove the tires. Once you remove all of the T25 screws you should be able to pull down the liner. The side lenses have a release clip accessed through a rubber plugged hole in the fender liner (see the Owners Manual). If you force it off you may break the locking tab.
Now use your finger and pull the fender liner down.
there is another T25 screw here that needs to be removed.
Once the screw is removed you need to disconnect the foglight clip. Use your needle nose pliers to pull the wire housing from the body of the car, then you can easily unclip it.
Now lets go back to the top and remove the headlights. Just unscrew the plastic tabs in the trunk and pull out the carpet. You should now see a black ****.
just pull it off and there is a double wall.
Use the 1/4" long extension and you need a 5mm deep socket.
This should only be a half turn then you will hear a loud snap, like something just broke. This sound is normal, the headlight will pop up, just pull it out. There are no wires, its already disconnected.
Old Apr 25, 2009 | 10:35 PM
SoCal955's Avatar
SoCal955 is infamous around these parts
Looks great and thanks for the very thorough write up.
Old Apr 26, 2009 | 08:35 AM
jrblackbox's Avatar
jrblackbox is infamous around these parts
Wow! nice write up. love the car.
Old Apr 27, 2009 | 06:51 AM
Thanks , Ive got a few more DIYs Ill be posting soon.
Old Jul 2, 2010 | 08:04 PM
TomllmoT's Avatar
TomllmoT is infamous around these parts
EXTREMELY helpful. thank you for taking the time to include pics!!
Old Jul 2, 2010 | 10:19 PM
rated_m's Avatar
rated_m is a glorious beacon of lightrated_m is a glorious beacon of lightrated_m is a glorious beacon of lightrated_m is a glorious beacon of lightrated_m is a glorious beacon of light
Nice write up, very informative.
Old Jul 5, 2010 | 02:30 PM
Sleepy996's Avatar
Sleepy996 is a jewel in the roughSleepy996 is a jewel in the roughSleepy996 is a jewel in the roughSleepy996 is a jewel in the rough
Awesome DIY mod.
Old Jul 5, 2010 | 04:11 PM
jhuang25's Avatar
jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !
great writeup!! nice pics, thank you. rep'd
Old Jul 6, 2010 | 02:11 PM
TheSt|G's Avatar
TheSt|G has a spectacular aura aboutTheSt|G has a spectacular aura about
Very nice writeup, and if this is any way indicative of the quality of your DIYs, I look forward to future threads.
Old Jul 6, 2010 | 07:27 PM
Fluid987's Avatar
Fluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond repute
gang
FYI ,I did this Mod on my old front bumper without taking the front bumper off ,Just a templete and dremmel and all went real well .siliconed it in with tough as nails . took less then 2 hours to complete
2lflat4
Nov 18, 2019 05:05 PM
Mackchacha
Jul 9, 2019 11:03 AM
JMon
Aug 21, 2015 08:20 AM
Aug 20, 2015 12:17 PM
