Strut noise
Old Apr 28, 2009 | 12:21 PM
Wanderer's Avatar
Wanderer is infamous around these parts
Strut noise
Hello,
I do not know a lot about struts and so I wanted to post this question to get some opinions.
I have an '08 CS with the interior panels currently out to try to track down the continuous rattles, creeks, cracks etc. I noticed the struts make a clapping sound going over bumps. It is akin to clapping two washers together, or loose change. There is also the spring/gas sound which seems normal. The tops of the struts also physically move up and separate on larger bumps.
Is this normal strut operation?
Old Apr 28, 2009 | 08:39 PM
chaud's Avatar
chaud is infamous around these parts
Stock suspension, or modded?
Old Apr 29, 2009 | 06:23 AM
Wanderer's Avatar
Stock suspension. Non-PASM
Old Apr 29, 2009 | 07:02 AM
renzop's Avatar
renzop is infamous around these parts
Why not go to the dealer? Its under warranty and they should be fixing this for free.
Old Apr 30, 2009 | 06:49 AM
Wanderer's Avatar
Rather learn how it operates and fix it myself if need be.
Old Apr 30, 2009 | 10:21 AM
chaud's Avatar
I currently have the same problem, but my suspension was recently worked on by a mechanic who could have done a better job.
Take a look at the top strut mounts, and see if the upper stop plate (concave washer) is loose and clanking around.
I forgot to ask, but has your suspension been recently worked on, or anything done to it? Has this clanking/chattering occurred since you've had the car, or just recent?
Old Apr 30, 2009 | 10:45 AM
Wanderer's Avatar
Thanks for the assistance. I checked and I cannot move the concave washer. It only clanks when the two washers separate on bumps. The car was a dealer demo and to my knowledge has never had suspension work. The problem seems to have been there from the start but naturally louder since the interior panel pieces are out.
rob4wellness
Oct 2, 2015 07:32 AM
DYL 911
Oct 1, 2015 02:47 PM
Ronny-
Sep 30, 2015 07:30 PM
stilov
Sep 27, 2015 10:01 AM
