Torn CV Boot Help
Old Aug 19, 2009 | 10:46 AM
mihernan's Avatar
mihernan is a splendid one to beholdmihernan is a splendid one to beholdmihernan is a splendid one to beholdmihernan is a splendid one to beholdmihernan is a splendid one to beholdmihernan is a splendid one to beholdmihernan is a splendid one to beholdmihernan is a splendid one to behold
Torn CV Boot Help
I have both inner CV boots starting to tear and throw grease. Just curious if this is something that should be handled by the dealer or if any old mechanic can take care of. Also, I've had experience with the outer boots tearing but not the inner ones, which seem a little more labor intensive. Has anyone experienced this issue and if so, how did you handle it? What price range should I expect to pay at either a dealer or a shop? Thanks,
-Mike
Old Aug 19, 2009 | 04:33 PM
Slowcart's Avatar
Slowcart has a reputation beyond reputeSlowcart has a reputation beyond reputeSlowcart has a reputation beyond reputeSlowcart has a reputation beyond reputeSlowcart has a reputation beyond reputeSlowcart has a reputation beyond reputeSlowcart has a reputation beyond reputeSlowcart has a reputation beyond reputeSlowcart has a reputation beyond reputeSlowcart has a reputation beyond reputeSlowcart has a reputation beyond repute
I hope someone can get you the info you asked for but if you don't mind what year is your Porsche and how many miles ?
Old Aug 20, 2009 | 07:12 AM
mihernan's Avatar
It's a 2002 base Boxster with 33k miles. I've taken it autocrossing three times in the recent past, so I dont know if that had an effect.
Old Aug 20, 2009 | 08:09 AM
driver8's Avatar
driver8 is infamous around these parts
Any mechanic should be able to handle this job, its even a DIY. Just make sure you get all new hardware for the re-install, don't use the old bolts & washers.
Old Aug 20, 2009 | 11:00 AM
EJ_2001_986_S's Avatar
EJ_2001_986_S is infamous around these parts
This job is definitely possible as a DIY. I did it on my '01 Boxster S. There's pretty detailed instructions on www.pedrosgarage.com (http://www.pedrosgarage.com/Site_3/R...alf_Axles.html) is the specific page you'd need.
Old Aug 20, 2009 | 12:19 PM
thnxbabe's Avatar
thnxbabe has a spectacular aura aboutthnxbabe has a spectacular aura about
If you decide that you don't want to DIY, getting it done on both sides will be in the $800-$900 range. As noted, replace everything, the parts are very cheap, most of the cost is the labor.
Old Aug 24, 2009 | 04:23 PM
echoboy's Avatar
echoboy is infamous around these parts
do you guys think that the CV wear is a result of just the number of years on the car? he certainly doesn't have that many miles on it.
Old Aug 25, 2009 | 06:01 AM
The wear is a little surprising on a base model Boxster. But if left to sit for a long period of time the grease becomes solid and rubber of those boots becomes brittle. My car is a 2001 and only had 23k on it in 2007 when I bought it. I then put about 10k on in a little less than two years and all 4 of mine cracked on my Boxster S. However, the joint angles are more severe on the Boxster S because the 6-speed transaxle is different than the 5 speed of the base model that the chassis was designed for. Boot kits are relatively cheap as far as parts. I'd go ahead and try to get them replaced to keep dirt from getting in there and grease from getting out. If you wait too long and the actual bearing material gets damaged you'll have to replace the whole joint, which is much more expensive.
jsedacca8
Feb 23, 2016 09:43 AM
Glasgo
Nov 30, 2015 02:37 PM
miken168
Oct 6, 2015 09:21 AM
jdubbya
Sep 28, 2015 04:58 PM
hsuku
Sep 27, 2015 04:39 PM
