Wheel Guide (pics)
Old Mar 19, 2010 | 09:44 PM
bill930p's Avatar
bill930p is infamous around these parts
Wheel Guide (pics)
I've been experimenting a lot with wheels on the Boxster over the last couple months. Just wanted to share what I've learned thru trial and error.
The car is lowered using Eibach springs.
I will try and update with more info as I get it.
First wheels I used:
The first wheels I tried were Champion RG5's. These are 19's with 993/996 offset. The rears are 9.5" - 10" wide I believe. Fronts were 8.5".
Front wheels bolted on with no spacers and standard size lugs.
I used a 1" spacer and 50mm lug bolts (longest I could find) in the rear. The bolts were still a little short (could only get about 5 turns) but worked. I put over 1k miles on this setup.
Tires were 235/35/19 front and 265/35/19 rear.
Second set of wheels I used:
The next set of wheels I tried were also Champion RG5's, but from a twin turbo. These are also 19's with 993/996 widebody offset. The rears are 10.5" - 11" wide I believe. Fronts were 8.5".
I used a 7mm spacer and 37mm lug bolts in the rear. I put over 500 miles on this setup. No rubbing.
Tires were 235/35/19 front and 285/30/19 rear.
I didn't originally try these as I assumed they would be too wide. As a side note; these are not the most aggressive wheels made for wide body 911's.. I tried a set of Avus wheels from my old TT which were half an inch wider in the rear and they did not work. This wheel and tire setup is as aggressive as you can go.
Third set of wheels I used:
The next set of wheels I tried were HRE 542R's. These are also 19's with 996 offset. The rears are 10" wide I believe. Fronts were 8.5".
I used a 50mm spacer and 50mm lug bolts in the rear. Just installed these, but seem to work well.
Tires are 235/35/19 front and 265/35/19 rear.
Old Mar 20, 2010 | 03:10 PM
Porsche323's Avatar
Porsche323 is just really nicePorsche323 is just really nicePorsche323 is just really nicePorsche323 is just really nicePorsche323 is just really nice
3rd set looks really good!
Old Mar 20, 2010 | 06:52 PM
wilson1's Avatar
wilson1 is infamous around these parts
looks good on the last set!
Old Mar 21, 2010 | 05:11 AM
Bob in NY's Avatar
Bob in NY is infamous around these parts
The 3rd set looks good but personally I'm not into the look of the wide lip on the Boxster. Just my .02...
Old Mar 21, 2010 | 12:43 PM
Max993's Avatar
Max993 is infamous around these parts
The first is perfect
Old Nov 10, 2010 | 10:24 PM
marlonm7's Avatar
marlonm7 is infamous around these parts
3rd set definitely for me!
Old Nov 11, 2010 | 12:13 PM
sclancypb's Avatar
sclancypb is infamous around these parts
the pics are nice but for this to be a helpful reference for others, you really need to post offsets and actual rim sizes...matching up spacers with guesses at offsets and rim widths doesnt tell us much...
Old Nov 11, 2010 | 01:09 PM
Sleepy996's Avatar
Sleepy996 is a jewel in the roughSleepy996 is a jewel in the roughSleepy996 is a jewel in the roughSleepy996 is a jewel in the rough
Ditto +1
Old Nov 13, 2010 | 03:44 PM
Johnny Danger's Avatar
Awaiting Email Confirmation
Johnny Danger is a splendid one to beholdJohnny Danger is a splendid one to beholdJohnny Danger is a splendid one to beholdJohnny Danger is a splendid one to beholdJohnny Danger is a splendid one to beholdJohnny Danger is a splendid one to beholdJohnny Danger is a splendid one to behold
Ditto ! Your data makes no sense. Especially the part about using a 50 mm spacer along with 50 mm lug bolts ????
Perkman87
Nov 19, 2015 05:31 PM
Wheel Experts
American Muscle
Aug 19, 2015 09:07 AM
Wheel Experts
Wheels/Tires
Aug 19, 2015 09:05 AM
