Camber adjustment on Boxster S?
Old Feb 17, 2011 | 01:38 AM
DavidM's Avatar
DavidM is infamous around these parts
I'm wondering what range of camber adjustments does the Boxster S suspension allow? ie. what is the possible maximum at front and back?
ps. I'm talking about a stock, non-PASM suspension on 987.1.
Thanks.
Old Feb 17, 2011 | 09:44 AM
Atob's Avatar
Atob is infamous around these parts
i just lowered mine with just spyder springs..
F:camber -.7 (caster +8.2)
R: camber -1.7
Old Feb 18, 2011 | 07:01 AM
DavidM's Avatar
Thanks for the info Atob. The rear sounds good, but only 0.7deg possible at the front ... or is that just your setting? I would like at least 1.
Cool. Where did you get them, and do you mind asking how much are they? I'm thinking about doing the same.
Old Apr 15, 2011 | 02:34 AM
DavidM's Avatar
Can anyone shed some light on how much camber can be dialled into 987.1 Boxster S with standard (non PASM) suspension?
Thanks.
Old Apr 15, 2011 | 07:19 PM
Cajundaddy's Avatar
Cajundaddy is infamous around these parts
Thanks.
-.7 is about all you can get in the front on stock struts. I just added PSS9s and lowered the front enough to get -2 degrees. Tire wear is much better now. You can add GT3 adjustable arms and get about 3 degrees negative in front.
Old Apr 16, 2011 | 04:14 AM
DavidM's Avatar
Shame ... I was hoping it's be at least -1.5. Any idea about the range at the back?
Old Apr 16, 2011 | 11:44 AM
Cajundaddy's Avatar
Yes. I got about -1.5 on the rear with stock struts.
flewis763
Sep 9, 2015 11:11 PM
