My First CPO 2008 Cayman
Old Mar 26, 2011 | 12:08 AM
LT63's Avatar
LT63 is infamous around these parts
Smile My First CPO 2008 Cayman
Hello Everyone,
I have just found this Porsche forum after purchase a CPO 2008 base Cayman with 10K miles and with the help of 1.9% interest rate from Porsche finance. It is a sweet and fantastic machine. I was smiling during the 3 hours ride from the dealership home. I bought it at Pioneer Porsche in San Diego, CA.
By the way, when you bleed your brakes? Do you also have bleed something else while you are at it?
Thanks.
LT
Old Mar 29, 2011 | 05:24 PM
bullitt44's Avatar
bullitt44 is infamous around these partsbullitt44 is infamous around these parts
Congrates and enjoy.
Old Mar 29, 2011 | 08:03 PM
lithium1330's Avatar
lithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud of
Thanks.
LT
Congrats. Bleed your brakes every 2 yrs with DOT4 fluid - I use Motul 600, but there are other options as well. If you use the car for street (i.e., no DE), you will be fine using DOT4 fluid you get from Pepboys/Advanced Auto Parts, etc. When you bleed your brakes, you can also bleed the clutch, which is located near the transmission. There is a bleeder valve tucked up out of the way on the left side, upper part of the transmission.
Old Mar 30, 2011 | 09:50 AM
Slik560's Avatar
Slik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond repute
Congrats on the buy. Now let's SEE it! Pictures welcome.
Old Mar 31, 2011 | 09:15 PM
buck986's Avatar
buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !
yes congrats..but lets have some pixs...
Old Apr 1, 2011 | 05:24 AM
RFFG's Avatar
RFFG Is a GOD !RFFG Is a GOD !RFFG Is a GOD !RFFG Is a GOD !RFFG Is a GOD !RFFG Is a GOD !RFFG Is a GOD !RFFG Is a GOD !RFFG Is a GOD !RFFG Is a GOD !RFFG Is a GOD !
Congrats.
Old Apr 1, 2011 | 08:39 AM
Karrera4's Avatar
Karrera4 is a name known to allKarrera4 is a name known to allKarrera4 is a name known to allKarrera4 is a name known to allKarrera4 is a name known to allKarrera4 is a name known to all
Hello Everyone,
Thanks.
LT
Congrats!
When bleeding the brakes, you can also get the Durametric software that cycles the ABS pump as your bleed. Start with the corner furthest from the resevoir (passenger side rear) and then select that brake with the computer and bleed when it tells you to. Repeat drivers side rear, passenger side front, drivers side front.
ebb
May 16, 2016 01:54 PM
mantruck
Feb 19, 2016 05:23 PM
Vrrooom
Sep 15, 2015 02:03 PM
ModBargains
Sep 12, 2015 12:55 PM
andbos
Sep 7, 2015 07:13 PM
