will this bi-xenon projector fit?
Old Oct 22, 2011 | 10:36 PM
baxster's Avatar
baxster is infamous around these parts
Hi, noobie here. Thx for your help in advance!
This will not be an easy plug-n-play (pnp). I will have to cut/modify the reflector to fit this larger projector, then hide it with a shroud.
I'm going this route instead of a smaller pnp projector because I want the most controlled illumination possible.
I'll probably buy the kit from TRS http://www.theretrofitsource.com/pro...roducts_id=141 unless someone knows a better vendor.
Length of Projector
Height
Width
The reflector in a non-litronic 04 986 is about 5.5" tall. The projector that I'll looking at is 100mm (~4") tall. Sounds doable unless I'm missing something.
About 2 months ago, a 986 owner did a bi-xenon retrofit seen below. He didn't specify what kind of projector he used, but I'm assuming it was a smaller pnp. It looks nice and similar to the Mini H1 kit that TRS sells.
Any opinions would help before I pull the trigger and get out the hacksaw. thx
Old Oct 23, 2011 | 01:42 PM
baxster's Avatar
If you have tried to modify your headlights, what was your experience?
mikerosi
Dec 6, 2018 06:23 PM
LiquidElephant
Aug 27, 2015 06:17 PM
Ferrari
Aug 24, 2015 04:35 PM
Mar48
Aug 24, 2015 01:13 PM
