IMS Failed in my 05 Boxster S - Replacement engine question
Old Sep 13, 2012 | 10:51 AM
cafulford's Avatar
cafulford is infamous around these parts
Well, it happened to me. What I was most concerned about and why I almost did not buy a Porsche. The IMS went and completely trashed the engine. As everyone here probably knows, 17k + labor for replacement from Porsche.
I purchased a power warranty from Interstate National Dealer Services and after inspection they said because the external bolt that leads to the IMS bearing was broken off, that that was the problem and they do not cover it because it was not an internally lubricated part. I have the best Porsche mechanic in Southwest Virginia who has worked on well over 1000 Porsche engines and has over 40 years experience telling them otherwise. I sense I will have to get a lawyer involved. I write this only to let everyone know that all these aftermarket insurance companies are weasels and to avoid this one at all costs.
But my question lies in my search for a less expensive alternative to a new Porsche engine. I am trying to do research on my own before I approach my mechanic.
Are all of the engines from 2005 - 2008 interchangeable? In other words, can I take a 2008 Cayman S engine and drop it in without any issues in my 2005? I found several places on the web that sells engines and has various years available from 2005 - 2008 and they say they will fit unmodified. Obviously, if I can search fro 4 years of engines instead of 1, I will have a better chance of finding one. I also know the later the year the better chance of another engine failure happening because of the same IMS problem.
Thanks so much in advance for your reply. I really appreciate it!
A very sad Porsche owner at the moment,
Charlie
Old Sep 13, 2012 | 12:13 PM
hroussard's Avatar
hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !
I think you should try to have a conversation with Porsche NA and suggest this is time for them to help you out in some way..... It's worth making the call.. Good luck!!
Old Sep 14, 2012 | 10:29 AM
cafulford's Avatar
Thanks for the reply...because I am the 2nd owner, they would not even consider it...
Old Sep 14, 2012 | 11:18 AM
hroussard's Avatar
If you don't shoot... you'll always miss the target!! Good luck!
Old Sep 14, 2012 | 01:32 PM
CosmosMpower's Avatar
CosmosMpower has much to be proud ofCosmosMpower has much to be proud ofCosmosMpower has much to be proud ofCosmosMpower has much to be proud ofCosmosMpower has much to be proud ofCosmosMpower has much to be proud ofCosmosMpower has much to be proud ofCosmosMpower has much to be proud ofCosmosMpower has much to be proud of
At least see if they will goodwil half of it or maybe cover the labor if you cover parts?
Old Sep 15, 2012 | 03:44 AM
kram96's Avatar
kram96 is infamous around these parts
How many miles do you have on your Boxster?
Jun 10, 2017 07:45 PM
PelicanParts.com
Aug 20, 2015 02:45 PM
Aug 20, 2015 12:17 PM
Jakk55
Aug 20, 2015 05:47 AM
