Blue tooth hookup,how much $$
Old Feb 8, 2014 | 11:09 AM
moresquirt's Avatar
moresquirt is infamous around these parts
Smile Blue tooth hookup,how much $$
My 06 Boxster s does not have Bluetooth,can it be installed,does it have to be done by porsche and what are the approx costs,got a ticket last summer for talking on cel phone not to mention hard to shift and hold phone at same time BUT im getting better at it
Old Feb 8, 2014 | 02:14 PM
SFGator987's Avatar
SFGator987 is infamous around these parts
Do you have iPod connection?
Old Feb 8, 2014 | 03:06 PM
moresquirt's Avatar
not that i have found,were would it be located.
Old Feb 8, 2014 | 03:57 PM
SFGator987's Avatar
Should be underneath the armrest.
Old Feb 8, 2014 | 04:25 PM
bigwong's Avatar
bigwong is infamous around these parts
He has an 06, there is no built in bluetooth. One aftermarket solution is called Parrot, as I recall. Either planet-9 or Cayman register would have more info on it.
Old Feb 8, 2014 | 04:37 PM
SFGator987's Avatar
I should of been more clear. Do you have the factory iPod connection like the below link? If so, you can buy a Bluetooth or even a Wifi transmitter and stream through the aux in jack. There are a bunch of other alternatives. Just depends on how much you would like to spend.
http://www.porschepartsnationwide.co...catalogid=5640
Old Feb 8, 2014 | 04:42 PM
bigwong's Avatar
An 06 has no bluetooth, no AUX-in, no ipod type attachment. It has nothing. You can send the radio in to Becker -Harmon for ~$100 and have an aux-in port connected to the CDR-24. There are other aftermarket solutions available.
Old Feb 8, 2014 | 05:20 PM
SFGator987's Avatar
Yes, I understand that. OP can go OEM route and add BT transmitter to tether his/her phone. The OEM setup has aux in and will allow you to talk on the phone when calls come in using your cellphone mic. The link I sent above.
The other option is to go the aftermarket route of FM modulator where you intercept the ant from back of radio and transmit via aux in and add BT transmitter. Both options are essentially the same since porsche isn't known for breakthrough electronics. And of course, OEM is supported by the factory. And you don't get true loss less audio.
A2DP BT format will allow for 2 way transmission and stereo if you choose to want mobile calling.
Check this article.
http://www.popularmechanics.com/_mob...r-car-16282689
If you want to go fully integrated, then it will require you to get a new head unit. And the next question would be if you have Bose?
Old Feb 8, 2014 | 06:04 PM
SFGator987's Avatar
Someone just posted a review over on P9 for over the air FM streaming and BT. This probably the least expensive solution.
http://www.planet-9.com/987-cayman-b...an-radios.html
Old Feb 9, 2014 | 09:43 AM
moresquirt's Avatar
yes i have Bose system
Old Feb 9, 2014 | 01:59 PM
moresquirt's Avatar
Thx everyone for your feedback,lots of options.will look into it.
ps:i rarely turn on the Bose Stereo(alough it does sound great) as i like to here the motor for shifting and useally have the top down BUT need to be able to receive a phone call without fumbling for my cel phone.
Old Mar 2, 2014 | 03:14 AM
amagalla's Avatar
amagalla is infamous around these parts
I have a Parrot CK3000 that I took out of my wife's car. It should be plug and play if you have ISO plugs on the back of your stereo (which I believe all do). It works perfectly to add Bluetooth (phone only) to your car. I'll let you have it for $50 if you're interested. Here is what I'm talking about.
Parrot Bluetooth
Let me know if you're interested.
Tony
Old Mar 2, 2014 | 06:48 AM
moresquirt's Avatar
Thx,got a SuperTooth for $29 (reg $80) that works great!
NC 996TT
Mar 23, 2023 06:19 AM
DB-Design-Group
Group Buys
46
Nov 3, 2015 11:27 AM
as4driver
Sep 10, 2015 09:32 AM
