Launch Control Inquiry
Old Mar 12, 2014 | 07:23 AM
UF2JZ4U's Avatar
UF2JZ4U is infamous around these parts
So I have a very Noob question.
Recently picked up a PDK 987.2 Spyder
Question is, how do I know if my car has launch control???
...and if it does, how is it applied in this vehicle.
Thanks!
Old Mar 12, 2014 | 01:55 PM
UF2JZ4U's Avatar
Anyone????
Old Mar 13, 2014 | 06:14 AM
UF2JZ4U's Avatar
Bueller???
More than 80 views and no one knows the answer???
I'm sorry if this is such a novice question but I bought the car second-hand at a non-Porsche dealership and they didn't have a spec sheet of the options. Just trying to educate myself...
Old Mar 13, 2014 | 07:23 AM
XLR82XS's Avatar
Got the owners manual and/or window sticker? Hit the sport plus button, put it in drive, hold the brake and floor the accel pedal. You'll know right away.
Old Mar 13, 2014 | 07:50 AM
UF2JZ4U's Avatar
LOL well didn't necessarily want to try launching the car that way if it doesn't have launch control...
Unfortunately no original window sticker, as it was purchased from a non-Porsche dealership. I have the owners manual but couldn't find anything that defines if you have Launch Control, just the if you have this option...
Was wondering if there is any defining button in the dash that would determine if I have it... I have sport and sport plus, just not sure if that means therefore I have launch contorol
Old Mar 13, 2014 | 08:40 AM
987spydr's Avatar
987spydr is infamous around these parts
If you have a PDK with Sport Chrono, then you have Launch Control. Enjoy.
Hit the sport plus button, put it in drive, hold the brake and floor the accel pedal. If you have the sport steering wheel with paddle shifters the right hand steering wheel spoke will light up with "Launch Control"
Old Mar 13, 2014 | 08:52 AM
UF2JZ4U's Avatar
Thanks 987Spyder!
That was very helpful : )
Now is that Clock that sits on my dash what denotes that I have "Sport Chrono" ???
Thanks!
Old Mar 13, 2014 | 08:57 AM
987spydr's Avatar
Yes. The "Clock" on the center of the dash and the fact that you have "Sport" and "Sport Plus" buttons on your center stack indicate you have the Sport Chrono package. My 2011 Silver Spyder has these and the Sport Steering Wheel with Paddle Shifters. In my opinion, it's the only way to order a car with the PDK transmission.
See My Garage photos here:
https://www.6speedonline.com/g/album/186182
Old Mar 13, 2014 | 09:13 AM
UF2JZ4U's Avatar
Sweet Ride!
Of course after you mentioned this Sport Steering wheel I started to google around with it. These look awesome! It looks like it separates the upshift on one side of the steering wheel and downshift on the other. Very intuitive as opposed to the push forward/push backward on my current steering wheel. Found some on ebay going for around ~$1700 , is it possible to just swap my steering wheel with one of those? Or does it need an additional/different ecu that controls the PDK shifting?
That setup is awesome, just like in my Maserati which makes sense, upshift on the right, downshift on the left : )
Old Mar 13, 2014 | 09:23 AM
987spydr's Avatar
Originally Posted by UF2JZ4U
Sweet Ride!
Yes. Just like a Maserati or Ferrari with regard to shifting.
As to changing it out I can't really tell you as mine came from the factory with it. I'm fairly certain there is no need for changes to the ECU. I would imagine the wiring harness for the steering column would have to be changed out to support the "Sport", "Sport Plus" and "Launch Control" lighting in the steering wheel spokes. The wiring for the paddle shifters would probably plug right in since the wheel you have has button shifters. You will, of course, loose all of the other functions that are associated with the steering wheel you currently have.
If you are indeed serious about making the switch, I strongly recommend you take it to a good Porcshe shop and get their opinion on what would be needed to complete the swap. Buying a Wheel on E-bay may not get you everything you need.
BTW. Welcome to the Spyder Club.
P.S. You can get a brand new wheel here:
http://www.suncoastparts.com/product...97GEN2PDKKnobs
Old Mar 13, 2014 | 11:44 AM
UF2JZ4U's Avatar
Thanks for all the insight 987Spyder!
So I called my local Porsche dealership and they have never retro-fitted a "Sport" Steering wheel onto a car, so the service manager even told me he wasn't sure what else would be needed to get the wheel to work...
He actually told me to research online forums that guys on here may know more about this procedure than he would!
So I think I'll start a new Thread inquiring if anyone has done this mod before.
Once again thanks for all the input! : )
Old Mar 13, 2014 | 08:31 PM
therock88's Avatar
therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !
Check over on the 997 Turbo Forum...There are lots of discussions and DIY, as well as people who change out their wheels. Some are quite simple and some require PIWIS Programming. Of note ALWAYS disconnect the battery before popping out the airbag, or you will get a CEL that has to be reset.
Good luck
DC
Old Mar 14, 2014 | 04:06 AM
tonyep's Avatar
tonyep is a glorious beacon of lighttonyep is a glorious beacon of lighttonyep is a glorious beacon of lighttonyep is a glorious beacon of lighttonyep is a glorious beacon of light
TECHART has a paddle shifters retrofit which convert your wheel to a proper left downshift right upshift paddle.
Old Apr 20, 2018 | 07:19 PM
negb's Avatar
negb is infamous around these parts
Is there any way using PIWIS or even aftermarket scanner to see how many times Launch Control was in use on particular Porsche car ?
Rguy
Apr 12, 2020 11:11 PM
albert@velosdesignwerks
BMW Vendor Classifieds
Sep 9, 2015 10:27 AM
Audi
Sep 9, 2015 10:13 AM
rohnin
Sep 7, 2015 01:10 PM
MrJoshua
Sep 6, 2015 02:06 PM
