Problem with USB to PCM with 2014 Boxster
Old Jul 2, 2015 | 02:38 PM
Mr Fantasy's Avatar
Mr Fantasy is infamous around these parts
I have a problem in trying to connect an external portable Toshiba Hard Disc Drive via USB (full of my music collection) to the PCM. It will not recognise the USB - it does not appear.
The bluetooth works ok with music from my phone and the radio is fine.
Can anyone help ?
Old Jul 7, 2015 | 03:40 PM
matt2ace's Avatar
matt2ace is a name known to allmatt2ace is a name known to allmatt2ace is a name known to allmatt2ace is a name known to allmatt2ace is a name known to allmatt2ace is a name known to all
Check the manual....I am not sure that solid state drives will work with PCM USB. I use a 64MB micro-SD card without any problem. I believe that the system will work with up to 128MB SD cards.
I would check with the dealer, they should have a more definitive answer.
Old Jul 9, 2015 | 09:51 AM
Mr Fantasy's Avatar
Thank you for your reply.
After many phone calls and mails and web searches - it seems that the hard drive (500GB) is too large to work with the P C M, so I have now given up that idea. Apparently it can work on smaller usb drives only.
I have a particularly large music collection and wanted to have it all i one place with a means of scrolling through the library
Old Jul 11, 2015 | 10:35 PM
chrismmm's Avatar
chrismmm is infamous around these parts
same issue here at first
i use mediamonkey to manage a large collection as well and have resorted to using 4 or 8gb usb drives to load up the jukebox. if i find a way around this limitation i will post on here any mods that work. cheers
Old Jul 12, 2015 | 03:40 PM
Mr Fantasy's Avatar
Thank you Chrismm
I read about this method and will consider doing it this way . I think to a max. of 40 gb
Old Jul 21, 2015 | 12:10 AM
GodLy's Avatar
GodLy is infamous around these parts
Format your HDD as FAT32 as i think you have NTFS at the moment..
Old Jul 27, 2015 | 02:10 AM
Mr Fantasy's Avatar
Thank you
2lflat4
Nov 18, 2019 05:05 PM
sypherdiaz
Aug 29, 2015 12:16 PM
gulf gt
Aug 27, 2015 10:27 AM
