should I change transmission mounts
I have a base 986 with 72k on the clock. I just ordered an engine mount,even though I don't feel there's anything wrong with it,but I read that changing the engine mount to a new one will make the car more precise and fun to drive in terms of gear changing. Now I was wondering if I should also change the transmission mounts as well. They don't leak, so I think they must still be ok, but should I just change them as well?
While bad engine or transmission mounts may affect shifting action to replace them with no clear indication they need to be replaced is probably a waste of money.
I dare say any improvement in shifting in the case the mounts were ok is probably more imagined than real.
Be aware what can affect shifting action and moving the car off from a dead stop smoothly is the freshness of the brake/clutch fluid.
Be sure if you have not done so within the last 2 years to have the brake fluid and clutch fluid flushed and bled.
Just 2.5 year old fluid in my Boxster caused clutch and shifting problems that were eliminated with a brake/clutch fluid flush/bleed.
Might mention braking action before and after the flush/bleed was unaffected as best I could tell.
My SOP is to only change something if it clearly needs changing.
ECS Tuning - BMW
Sep 24, 2015 08:55 AM
