Are you experiencing cabin wind buffeting noises? You will probably notice this noise when cruising with the window down. We have a simple and easy solution to eliminate that noise once and for all!
Check out the AWE Foiler™ to get rid of the noise: Click Here
Here are some features of the Foiler™:
The elegant solution for Porsche 718/981/991 wind buffeting
UV-stabilized injection-molded plastic for the perfect OE-style look
Combats buffeting, both on the track and on the street
Allows for “single window” down driving without buffeting
Perfect OE-like fitment
Simple, quick installation
Fits Coupe, Cabriolet and Targa models
Includes driver’s side and passenger side fitments
@9~Factor - It is definitely a simple solution. We have yet to see any models with this issue fixed from the factory. As far as we know, we have not seen a downside to this solution. The only thing that may be tricky is that in some cases we found that some people had to take the door panel off to install(not common).
