BBi Autosport 4th of July Sale on Porsche 981 GT4 Roll Bar, Seat Base, Suspension
Old Jul 2, 2018 | 06:28 PM
BBiAutosport's Avatar
BBiAutosport is infamous around these parts
Attachment 536876
What’s the best way to celebrate our country’s independence??? Supporting American-made products!!! BBi Autosport is offering a week long 10% off sale on selected BBi Autosport products including roll bars, exhausts, and safety upgrades from now until July 6. Promotion is also valid at participating authorized dealers so contact us for more details!!! Here are the BBi Porsche 981 GT4 upgrades that are be on sale:
BBi Autosport 981 GT4 StreetCup Roll Bar
Key Features
  • Chrome moly steel tubing utilized for excellent strength to weight ratio
  • Modular construction to allow access to engine for servicing without removing entire roll bar
  • Shoulder harness mounting crossbar positioned at appropriate height as per Schroth's instructions
  • TIG welded and utilizes "X" braces on rear section for superior strength and rigidity
  • Mounts to frame structure and rear strut tower to provide strongest mounting points and maximum protection
  • Utilizes laser cut mounting plates & inner diameter tube clamps that are CNC turned and milled for a precise fit
  • Designed to work with stock or any aftermarket seats on the market
  • Minimal effect on seat travel to accommodate taller drivers
  • Can be used with stock seat belts or 6 point harnesses for track use
  • Designed to work with wrap-around style harnesses while optional eyelet bolt provisions are available for clip-in harnesses
  • OEM fit & finish. The main hoop contours entire arch of the roof with an even curve
  • Finished in satin black powder coat. Other colors available
  • Bolt-in installation requires no drilling and minimal carpet trimming
BBi Sub-Belt Mount Porsche 991 GT3/ GT3RS / Cayman GT4
Features
  • Provides mounting location for sub-belts at the proper 10-20° angle regardless of the seat position
  • Precision CNC laser cut and bent from one piece high carbon steel for superior strength
  • Stylish design with laser cut BBi logo and durable satin black Powdercoat finish
  • Attaches to seat assembly using factory mounting points with all hardware included
  • Compatible with Porsche 991 GT3 and 981 Cayman GT4 models equipped with Sport Bucket Seats
  • Made in the USA
BBi Seat Base & Slider Kit Porsche 996/997/991/987/981 Seat
The BBi Autosport race spec seat mounts are a direct bolt into the factory mount location for a hassle free, easy installation for your competition race seat. The BBi Autosport Seat mounts have a large range of adjustment options allowing fitment for all major FIA and SFI approved seat brands and offers an integrated 5 and 6 point sub belt mounting location.The wide range of adjustment covers almost all possible seating preferences to properly seat drivers of all sizes. CAD designed, CNC laser cut and formed from one piece of .125” (1/8”) carbon steel with no welds to maximize strength and stiffness. All mounts are powder coated with a wrinkle black base and satin black sides.
Features
  • Precision CNC laser cut and bent from one piece of 1/8” 3mm carbon steel (base & side mounts)
  • Multi way adjustability
  • High strength sliders, mounts to base with 4 bolts per slider
  • Integrated 5 and 6 point sub belt mounting locations
  • No modifications to vehicle or any seat mount components are required for installation
  • Uniquely designed for Porsche vehicles for the best possible fitment
  • Mounts to factory bolt locations with precise factory fitment
  • Fits all major FIA/SFI approved seats up to 17”
  • 14-3/4”¬(375mm) to 17-1/2”(445mm) width adjustments (standard side mounts)
  • 16”¬(375mm) to 18-3/4”(445mm) width adjustments (optional wide side mounts)
BBi Autosport Porsche Cayman GT4 StreetCup Suspension Package
(Click on images for higher resolution)
The BBi Autosport Street Cup Suspension Package further improves the handling of the Porsche Cayman GT4 and make it even more track-worthy. With many years invested in development and testing on both the track and street, this complete suspension upgrade package will elevate the driving experience beyond the already impressive factory performance levels.
BBi Street Cup Suspension Components Typically Share The Following Features:
  • Hard tested on the street and track
  • Provides additional adjustment range
  • Helps maintain proper suspension geometry
  • Utilizes turnbuckle design to be lengthened or shorten links to desired specifications
  • Eliminates factory rubber bushings for improved suspension feedback
  • Direct bolt-On replacement and requires no modification to the vehicle
  • Made of precision CNC machined 6061-T6 aerospace grade billet aluminum
  • Precision Teflon lined spherical rod ends for smooth operation and long life
  • Discrete black anodized finish for increased corrosion resistance
  • Made in USA
BBi Autosport Front Bump Steer Kit
  • Helps eliminate bump steer by maintaining proper front end suspension Geometry
  • Utilizes misalignment rod ends of the arm to provide maximum articulation
  • Highly recommended for vehicles that have been lowered
  • Each kit includes pair of 2 Links
BBi Autosport Rear Adjustable Toe
  • Provides additional rear toe adjustment
  • OEM link is non-adjustable and eccentric bolt provides limited adjustment range, causing excessive tire wear and handling issues.
  • Helps maintain proper rear end suspension geometry
BBi Autosport Front & Rear Thrust Arm Kit
  • Connects the Lower Control Arm to the subframe
  • Provides precision caster adjustability
  • Spacers included for setting stock or anti-squat and anti-dive configurations
  • Each Kit Includes Pair of 2 Links
  • Fits both front and rear axles
BBi Autosport Front & Rear Adjustable Thrust Arm Bushing Kit
  • Provides two eccentric mounting points
  • Used to adjust for increasing or decreasing wheelbase, and adjustable caster.
  • A must-have for extended lower control arms (GT3 control arms or eccentric monoballs) to correct for unintended caster change
  • Compatible with all stock Porsche 996 and 997 lower control arms (including Porsche Motorsport Cup arms)
  • Sold as a set of 2 or a Complete set of 4
BBi Autosport Lower Control Inner Spherical Bearing (Mono-ball) End Kit:
  • Upgrades 981 GT4 front and rear control arms to improve chassis response by eliminating rubber bushings
  • Improved inner bearing flange design. Slimmer and lighter than factory OEM & Cup style
  • High-strength sealed steel alloy spherical bearings, completely serviceable unlike the motorsports arm
  • Also fits all 986, 987, 996, 997 with upgraded GT3/RS OE front or rear split control Arms
  • Each kit includes a pair of 2 inner bearing flanges
BBi Autosport Porsche Cayman GT4 StreetCup Rear Wing Supports
The highly anticipated BBi GT4 wing supports are direct bolt-on parts that raise the factory wing up into the cleaner air by 80mm. CNC machined out of 6061-T6 billet aluminum in Southern California, the pieces are beautifully contoured to look like they came from the factory instead of being an afterthought.
Features
  • Increase 80mm Over the OEM Wing Height
  • Made of Precision CNC Machined 6061-T6 Billet Aluminum
  • Durable Hard Anodized Flat Black Finish
  • Easy to Install. No Drilling or Cutting Required
  • Designed to Use with OEM Weather Seals & Hardware
  • Compatible with Porsche 981 Cayman GT4 Model Only
  • Made in the USA
Please email us at Jerry@BBiAutosport.com or Sales@BBiAutosport.com to place an order or for all questions and inquiries!!!
- jerry@bbiautosport.com
BBiAutosport
Jun 12, 2018 02:14 PM
BBiAutosport
Dec 8, 2017 12:35 PM
BBiAutosport
Nov 24, 2017 01:50 AM
