BBi Autosport 4th of July Sale on Porsche 997 Turbo Roll Bar, Slave Cyl Seat Base,
Old Jul 2, 2018 | 06:24 PM
BBiAutosport's Avatar
BBiAutosport is infamous around these parts
Attachment 1
What’s the best way to celebrate our country’s independence??? Supporting American-made products!!! BBi Autosport is offering a week long 10% off sale on selected BBi Autosport products including roll bars, exhausts, and safety upgrades from now until July 6. Promotion is also valid at participating authorized dealers so contact us for more details!!! Here are the BBi Porsche 997 Turbo upgrades that are be on sale:
BBi Autosport StreetCup Porsche 996/997 Roll Bar
Features
  • 1.625" x 0.095" 4130 chrome moly steel tubing utilized for excellent strength to weight ratio
  • Made from 4130 chrome moly steel tubing (1.5" x .120" main hoop & 1.5" x 0.95" rear hoops) for excellent strength to weight ratio
  • TIG welded and utilizes "X" braces on both front and rear sections for superior strength and rigidity
  • Mounts to front seatbelt mounts and rear strut towers
  • Utilizes laser cut mounting plates & inner diameter tube clamps that are CNC turned and milled for a precise and seamless fit
  • Designed to work with stock or any aftermarket seats on the market
  • Can be used with stock seatbelts or 6 point harnesses for track use
  • Designed to work with wrap-around style harnesses while optional eyelet bolt provisions are available for clip-in harnesses
  • OEM fit & finish. The main hoop contours entire arch of the roof with an even 3/16 inch gap
  • Finished in satin black powder coat. Other optional colors available
  • Designed to fit all models of the 996 and 997 chassis including the Carrera, Turbo, GT2, and GT3
  • Compatible with factory Bose subwoofer
  • Bolt-in installation requires no drilling and minimal carpet trimming
  • Made in USA
BBi Seat Base & Slider Kit Porsche 996/997/991/987/981 Seat
The BBi Autosport race spec seat mounts are a direct bolt in to the factory mount location for a hassle free, easy installation for your competition race seat. The BBi Autosport Seat mounts have a large range of adjustment options allowing fitment for all major FIA and SFI approved seat brands and offers an integrated 5 and 6 point sub belt mounting location.The wide range of adjustment covers almost all possible seating preferences to properly seat drivers of all sizes. CAD designed, CNC laser cut and formed from one piece of .125” (1/8”) carbon steel with no welds to maximize strength and stiffness. All mounts are powdercoated with a wrinkle black base and satin black sides.
Features
  • Precision CNC laser cut and bent from one piece of 1/8” 3mm carbon steel (base & side mounts)
  • Multi way adjustability
  • High strength sliders, mounts to base with 4 bolts per slider
  • Integrated 5 and 6 point sub belt mounting locations
  • Stylish design with laser cut BBi logo and durable satin black Powdercoat finish
  • No modifications to vehicle or any seat mount components are required for installation
  • Uniquely designed for Porsche vehicles for the best possible fitment
  • Mounts to factory bolt locations with precise factory fitment
  • Fits all major FIA/SFI approved seats up to 17”
  • 14-3/4”¬(375mm) to 17-1/2”(445mm) width adjustments (standard side mounts)
  • 16”¬(375mm) to 18-3/4”(445mm) width adjustments (optional wide side mounts)
BBi Autosport Porsche 996 & 997 Turbo Clutch Slave Cylinder Conversion Kit
Always striving for innovation, BBi Autosport is proud to announce our new highly anticipated Clutch Slave Cylinder Conversion Kit for the Porsche 996 and 997 Turbo. After successfully tested on both the streets and tracks for over a year, the Clutch Slave Cylinder Conversion is scheduled for an official release very soon in June.
The factory power-assisted clutch system has always been the Achilles heel for the Porsche 997 Turbo. Utilizing the power steering system to help reduce the force needed to depress the clutch pedal, it is a flawed design that delivers a mushy pedal feel with poor feedback, and is highly prone to failure. Our system addresses both of those issues by eliminating the problematic factory power-assist system for improved reliability and pedal feedback. Unlike other kits, our system is designed be used with OEM clutch master cylinder, hose, and spring pack. This eliminates the need for additional parts and making our kit a complete plug and play solution.
The other kits on the market simply adapts factory 996 GT2 parts with aftermarket brackets and caps off the power steering pump with plugs. Our kit is our very own proprietary design and does not plug the power steering pump because the plugs can fail. Instead, the power steering fluid is routed through the unit to simulate the factory system. With the failure of the factory system inevitable, this is a must upgrade for the 996 and 997 Turbo to achieve the excellent pedal feedback and reliability similar to that of the Porsche 997 GT2 and GT3 without compromising drivability.
Key Features
  • Eliminates the problematic OEM power-assisted clutch slave cylinder for improved reliability
  • Significantly improves the clutch feel and engagement
  • Designed to be slightly softer than the factory 996 GT2 conversion kit for excellent drivability
  • Proprietary plug and play design
  • Retains clutch master cylinder, hose, and spring pack
  • Requires less installation time than slave cylinder conversion kits
  • Does not adversely affect clutch life
  • Precision CNC machined and hard anodized aluminum construction
  • Hard anodized 7075 aluminum piston
  • Designed for Porsche 996 and 997 Turbo
BBi Autosport Porsche Cayman 996/997 StreetCup Suspension Package
The BBi Autosport Street Cup Suspension Package further improves the handling of the Porsche 996/997 to make it even more track-worthy. With many years invested in development and testing on both the track and street, this complete suspension upgrade package will elevate the driving experience beyond the already impressive factory performance levels.
BBi Street Cup Suspension Components Typically Share The Following Features:
  • Hard tested on the street and track
  • Provides additional adjustment range
  • Helps maintain proper suspension geometry
  • Utilizes turnbuckle design to be lengthen or shorten links to desired specifications
  • Eliminates factory rubber bushings for improved suspension feedback
  • Direct bolt-On replacement and requires no modification to the vehicle
  • Made of precision CNC machined 6061-T6 aerospace grade billet aluminum
  • Precision Teflon lined spherical rod ends for smooth operation and long life
  • Discrete black anodized finish for increased corrosion resistance
  • Made in USA
BBi Autosport Front & Rear Lower Billet Control Arm Kit
  • Improved two piece 996 GT3 lower control arm design
  • Stronger than cast motorsport Cup arms
  • Allows proper camber adjustment 996 & 997 Models
  • Uses GT3 shims to adjust camber & lower control arm length (sold separately)
  • High-strength steel alloy spherical bearings, completely serviceable unlike the motorsports arms
  • Sealed monoball inner bearing
  • Allows easy access to inner arm hardware
  • Includes adjustable thrust arm bushings to adjust adjust caster and wheelbase
  • A must have for all track and race enthusiast
  • Each kit includes pair of 2 arms
  • Fits both front and rear axles
BBi Autosport Front Bump Steer Kit
  • Helps eliminate bump steer by maintaining proper front end suspension Geometry
  • Utilizes misalignment rod ends of the arm to provide maximum articulation
  • Highly recommended for vehicles that have been lowered
  • Each kit includes pair of 2 Links
BBi Autosport Rear Adjustable Toe
  • Provides additional rear toe adjustment
  • OEM link is non adjustable and eccentric bolt provides limited adjustment range, causing excessive tire wear and handling issues.
  • Helps maintain proper rear end suspension geometry
BBi Autosport Front & Rear Thrust Arm
  • Connects the Lower Control Arm to the subframe
  • Provides precision caster adjustability
  • Spacers included for setting stock or anti-squat and anti-dive configurations
  • Each Kit Includes Pair of 2 Links
BBi Autosport Front & Rear Adjustable Thrust Arm Bushing Kit
  • Provides two eccentric mounting points
  • Used to adjust for increasing or decreasing wheelbase, and adjustable caster.
  • A must-have for extended lower control arms (GT3 control arms or eccentric monoballs) to correct for unintended caster change
  • Compatible with all stock Porsche 996 and 997 lower control arms (including Porsche Motorsport Cup arms)
  • Complete set of 4 (2 front & 2 rear)
BBi Autosport Rear Upper Control Arm Kit
  • Link the rear wheel carrier to the sub-frame.
  • Allow adjustment of track width and kinematic toe.
  • Complete set of 4
Please email us at Jerry@BBiAutosport.com or Sales@BBiAutosport.com to place an order or for all questions and inquiries!!!
BBiAutosport
GT3/GT2/GT Vendor Classifieds
Jan 8, 2018 10:24 AM
BBiAutosport
Dec 21, 2017 02:24 PM
ewholz
Mar 16, 2016 02:08 PM
