987.2 suspension measurements, anyone have them?
I'm working on a project where I'm using the 987.2 suspension components and need to get a base line location for the LCA. I'm looking for front and rear C-C on the inner lower control arm bolts where they mount to the frame bits as well as the C-C on the front and rear strut tops. Also stock ride height from that same bolt to the ground. It's been a while since I've been under one, so if the inner bolts aren't easy to get to, I could use any reference point on the LCA as long as it's consistent. I have the giblets here and can calculate the differences.
+/- 1/8" accuracy is fine at this point. I'll model the rest. Anyone in the Dallas Texas area that can let me crawl around under their cayman/boxster for 20 minutes? Or if anyone has measured the suspension for a suspension geometry modeling program, I'd consider purchasing the information.
Thanks!
-Brad
Thanks!
-Brad
03EvoIII
Cayenne 955/957
10-21-2011 12:49 PM
KA 997TT
07-31-2009 09:42 PM
dbelleperc
07-14-2004 09:10 PM
