2000 boxster wont turn over
Old Apr 26, 2021 | 07:16 AM
Sw17429's Avatar
Sw17429 is infamous around these parts
I have had this older model boxster for 2 years now. Only driven in spring and fall for the most part. Has started religiously except for this Spring. Bought a new Battery old one died over the winter. Garage kept. Hopped in the other day after replacing the battery and cannot get it to fire...will not even give a hint it is about to turnover. Cranks fine just will not start. Any ideas before I have it towed and spend a buttload of money??
thanks
Scott
Old Apr 29, 2021 | 11:51 AM
jg_atl's Avatar
jg_atl is infamous around these parts
So the starter motor works and the battery is good. All it needs to run is fuel and a spark. Did you put any conditioner in the fuel before you stored the car for the winter. Gasoline can get pretty nasty sitting for long periods of time. May want to drain the fuel and refill with fresh and hope that the fuel lines aren’t all gummed up. If not getting spark, then the likely cause is either the immobilizer unit under the driver’s seat or the crank position sensor going bad. It is pretty easy to find out if you are getting spark - remove one of the spark plugs and then reconnect it to its coil pack and ground the outside of the plug to the engine, then get someone to try to start the car while you are looking at the spark plug for a spark to arc across the electrodes. Careful - high voltage coming from coil pack.
Old May 14, 2021 | 03:05 PM
BOOSTTT's Avatar
BOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to behold
Test the fuel pressure as well.
Old Aug 10, 2021 | 04:20 PM
ike84's Avatar
ike84 is infamous around these parts
It may be your clutch switch - if its not making good contact and this is a US spec car then the ecu will not activate the starter motor.
Old Sep 6, 2021 | 05:06 PM
Targaone1's Avatar
Targaone1 is infamous around these parts
No start
Not clutch switch. The clutch switch prevents the starter from running. So if it spins up its not that. Fuel pump or relay is my first place to look
UnholyActs
Feb 12, 2021 09:07 AM
RogerKoo2000
Nov 14, 2013 01:19 PM
oneatthebar
Jul 11, 2012 12:01 PM
scottfromnapa
Apr 16, 2008 10:47 AM
99boxter
Nov 3, 2004 06:46 AM
