option quest--chrono
Old Aug 29, 2007 | 06:48 PM
squid's Avatar
squid is infamous around these parts
the "sport chrono" option package includes the adjustable dampers and the exhaust opening button thingy right?
and on a related note, can the adjustable dampers be replaced, while maintaining the adjustability from the cockpit?
TIA
Old Aug 30, 2007 | 10:55 AM
SD1's Avatar
SD1
SD1 has a spectacular aura aboutSD1 has a spectacular aura aboutSD1 has a spectacular aura about
No, sport chrono (standalone option) has a secondary ECU map that allows for slightly quicker throttle response and as part of the package allows you to personalize some features like the door locks and includes the super groovy stopwatch on the dash.
If your car is equipped with PASM and or Sport exhaust both of which are separate stand alone options, the sport button for the Chrono will simultaneously select the sport mode of PASM and engage the sport exhaust.
Old Aug 30, 2007 | 02:34 PM
ZEMDOGG's Avatar
ZEMDOGG is infamous around these parts
Also PASM goes into an even SPORTIER mode than PASM without sport chrono. It goes soft - sport- hard sport.
Old Aug 30, 2007 | 02:54 PM
SD1's Avatar
SD1
I didn't know that and I also remembered it loosens up PSM a little as well.
Old Aug 30, 2007 | 03:23 PM
squid's Avatar
wait, so I want PSAM and NO chrono?
the PSAM gives you the magic button as well, right?
Old Aug 30, 2007 | 03:44 PM
ZEMDOGG's Avatar
IF you want all the adjustability you want both
If you get both options you would have the following:
Normal suspension(all buttons off)
Sport suspension(Pasm button pressed)
Even sportier suspension(Pasm button and sport button pressed)
Old Aug 30, 2007 | 05:25 PM
SD1's Avatar
SD1
If you aren't going to upgrade your suspension to fully adjustable coilovers I would get PASM. I hear a lot of good things about the Porsche setup and I have had it on another car and thought it was great.
Chrono allows you have self locking doors, adjust to unlock one or both doors, set up the interior lighting to stay on for 30 sec after you get out of the car... and the secondary ECU map that allows for slightly improved throttle reponse and higher limits on PSM. If you drive hard get it. I would have ordered it just to get the auto door locks.
Old Aug 31, 2007 | 07:48 AM
r6tanz's Avatar
r6tanz is infamous around these parts
get the sport chrono.. i regret not getting it.... it also looks cool to have a guage on ur dash
Old Aug 31, 2007 | 09:53 AM
MSCaymanS's Avatar
MSCaymanS has much to be proud ofMSCaymanS has much to be proud ofMSCaymanS has much to be proud ofMSCaymanS has much to be proud ofMSCaymanS has much to be proud ofMSCaymanS has much to be proud ofMSCaymanS has much to be proud ofMSCaymanS has much to be proud ofMSCaymanS has much to be proud ofMSCaymanS has much to be proud of
I have both and think they're great. Unless you plan on aftermarket coilovers then definitely get the PASM.
ModBargains
991 Vendor Classifieds
Oct 13, 2015 03:57 PM
ModBargains
991 Turbo Vendor Classifieds
Oct 13, 2015 03:56 PM
ModBargains
GT3/GT2/GT Vendor Classifieds
Oct 13, 2015 03:55 PM
ModBargains
997 Turbo Vendor Classifieds
ModBargains
997 Vendor Classifieds
Oct 13, 2015 03:53 PM
