Changing gear oil, How do you refill with “squirt” bottle?
Old Sep 25, 2007 | 12:11 AM
PK2's Avatar
PK2
PK2 is infamous around these parts
Question: My manual shows the fill plug right on a plate on the side of trans. It seems it would be impossible to get the whole bottle up there to squeeze in the oil. If I’m right, how do you get the oil in, put a hose on it and hang somewhere above filler hole like an I.V.? I seem to recall using some sort of hand soap type pump with a hose the last time I did this.
Also, manual states that the oil should be 11mm below the bottom of the fill hole. Dose it really matter?
Ideas?
P.S. Background: I’ve got a tired 5 speed. Someone here or there swore that switching out the gear oil with Penzoil Synchromesh can gives your transe a new lease on life. Believe me, I’m a natural corn skeptic, but if it makes my fading transe. a little more pleasurable in it’s twilight months, $18 is a gamble I can take.
Old Sep 25, 2007 | 12:19 AM
blinkwatt's Avatar
blinkwatt is infamous around these parts
I've heard that Redline MT-90 is crap on 6-spds....can't say the same for the 5-spds. I used it on my 99' and LOVED the results,smother shifts.
I transfered the oil from the Redline container to an old Honda lawnmower oil container(thing and narrow) and poured it in that way.
Hope that helps.
Old Sep 25, 2007 | 12:26 AM
PK2's Avatar
PK2
Hope that helps.
Sounds like a direction...
Thanks,
PK
BLKonBLK911C4S
NorCal
Aug 29, 2015 03:20 AM
LiquidElephant
Aug 27, 2015 06:17 PM
gulf gt
Aug 27, 2015 10:27 AM
00aston
Aug 27, 2015 12:01 AM
The Oss
Aug 24, 2015 08:19 PM
