New Guy (with a question)
Old Oct 1, 2007 | 02:18 PM
pcs416's Avatar
pcs416 is infamous around these parts
Hey Guys! First time Porsche owner... a new (to me)
2004 Cayenne S
Jamara
Light Wood Package
50,000km
(pics to come)
So far I have had the bypass and muffler done. I found a local guy who made custom bypass pipes and installed 2 Magnaflow mufflers for about $1000 CAD (instead of $4000 at the dealer). Sounds awesome and seems to have given more low end (sound clip to come).
Here is the question.
Has anyone had any downshifting vibrations after installing an aftermarket exhaust? This was only noticeable after the exhaust work and after about a week has seem to improve a lot but still happens in some scenarios. Mostly when coming off of the gas and not braking, right around 60km/h.
Is this due to less back pressure? Will the ecu eventually 'learn' about the new exhaust?
Thanks,
Luke
Old Oct 2, 2007 | 01:24 AM
MeanMachine's Avatar
Welcome to the forum and I've done exhausts work to my car and very satisfied, the only drawback to the Cayenne are faulty electronics ie Panaromic roof getting stuck, PCM freezing and parkingsensors not working in most occassions.
Old Oct 2, 2007 | 11:23 AM
cayenned's Avatar
cayenned has a spectacular aura aboutcayenned has a spectacular aura about
I have an 04 S as well.....you should get your ignition coils, cardan shaft checked out, the coils are a common problem on early cayennes.
welcome to the forum
Old Oct 2, 2007 | 06:19 PM
Cpa4S's Avatar
Cpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to behold
was it a referral to the shop? i assume it was Pfaff quoting $4k?
Old Oct 10, 2007 | 01:26 PM
pcs416's Avatar
update...
so I am finally registered and can now reply to posts.
turns out that there wasn't enough back pressure which caused issues with the auto tranny and its downshifting for engine braking. i added 2 resonators and it has helped a lot, a bit less sound but 99% of the vibration is gone.
all of the work was done at Scott's Hot Rod - these guys do awesome work, pm me for more details
btw - it was pfaff quoting $4k+
turkish1
Nov 11, 2015 09:01 PM
pilotscottb
Sep 1, 2015 10:29 PM
gulf gt
Aug 27, 2015 10:27 AM
Lucid Moment
Aug 20, 2015 02:22 PM
