Ride quality better with Module VS Links?
Old Feb 21, 2008 | 01:24 AM
hblocal's Avatar
hblocal is infamous around these parts
I would assume no matter which route you go, module or drop links, if you drop both to same height that ride quality would be the same right? Maybe a module will not allow you to go as low as with links?
One thing I don't understand is when people say they like the module better because of the flexibility of being able to adjust their height via their air suspension lever. I can still adjust my ride height with my drop links its just its lower on each level. Isn't that the same as with a module?
Old Feb 21, 2008 | 01:29 AM
Seattle996's Avatar
Seattle996 has a reputation beyond reputeSeattle996 has a reputation beyond reputeSeattle996 has a reputation beyond reputeSeattle996 has a reputation beyond reputeSeattle996 has a reputation beyond reputeSeattle996 has a reputation beyond reputeSeattle996 has a reputation beyond reputeSeattle996 has a reputation beyond reputeSeattle996 has a reputation beyond reputeSeattle996 has a reputation beyond reputeSeattle996 has a reputation beyond repute
You read my mind... I'm also curious
Old Feb 21, 2008 | 01:36 AM
hblocal's Avatar
haha funny, we both just had our links put in this week. do you have pics to post?
Old Feb 21, 2008 | 11:52 AM
ammo_collector's Avatar
ammo_collector is infamous around these parts
I have the Techart module. Things I like:
- When you lock your car, it goes into the lowest setting automatically
- No splicing = switch back to stock literally in 30 seconds
- Although you can go low, your terrain heights are basically the same as stock
Old Feb 21, 2008 | 11:55 AM
hblocal's Avatar
I thought I read a member here mention that they still had to splice the wires and that the module was not plug and play. Was that a different brand module? Which tuners modules require splicing and which don't?
Old Feb 21, 2008 | 01:01 PM
atlshaver's Avatar
atlshaver has a spectacular aura aboutatlshaver has a spectacular aura about
FVD does require it but it isn't that bad - took about 20 minutes.
Old Feb 22, 2008 | 05:40 PM
No, my TechArt module requires no cutting and plugs in and out within seconds.
Old Feb 22, 2008 | 05:50 PM
mja 996TT's Avatar
Member
mja 996TT is infamous around these parts
I have the TechArt module as well; 'plug and play' !
I think the Rinspeed may require splicing.
Old Feb 22, 2008 | 08:25 PM
hblocal's Avatar
So with the module you are still using the lever on the center console to adjust the height right? So after installing the module you still only have 3 choices of height plus the load level?
Old Feb 24, 2008 | 11:21 AM
Yes, with both the module and links you have the same number of choices as stock and with both you still use the center console lever.
Old Feb 24, 2008 | 07:55 PM
copasetic222's Avatar
copasetic222 is infamous around these parts
If you must splice, how hard is it to remove the unit at a later date?
Old Feb 27, 2008 | 02:25 AM
hblocal's Avatar
Any of you guys know how low from stock each of these modules will lower the car? I know with links you can go up to about 1.5" - 2' lower than stock.
And I'm assuming that ride quality would be the same then with either module or drop links.
Old Feb 27, 2008 | 07:37 AM
Fracky's Avatar
Fracky is infamous around these parts
Is there any negative side affects from using a lowering module? Are the before-after pictures someone could post? Finally, where can you order this unit?
Old Feb 27, 2008 | 08:01 AM
atlshaver's Avatar
You simply remove the module and insert a plug in the connector that restore the original circuitry.
Mark @ AIM Performance
119
Jul 28, 2021 08:07 AM
Jul 29, 2019 11:13 AM
Armytrix_F1_Exhaust
Jul 7, 2019 11:31 PM
Aug 19, 2015 06:35 PM
Nissan GTR
Aug 19, 2015 02:11 PM
