HELP, programming garage door opener...
Old Apr 7, 2008 | 07:31 PM
Hsiang613's Avatar
Hsiang613 is infamous around these parts
Originally Posted by copasetic222
I don't know why, but if your garage opener has rolling code (which makes it harder to open incorrectly), that's how you do it. I've done it with Audi, VW, BMW, Mercedes and Porsche and you do it exactly the same on all of them.
i wish it has a easier way to do it...
Old Dec 29, 2008 | 01:32 PM
'08C4S's Avatar
'08C4S has a spectacular aura about'08C4S has a spectacular aura about'08C4S has a spectacular aura about
Had a little difficulty programming the garage opener in an '08 GTS myself. Changing to a fresh battery in the garage opener did not help right away either. Had to play around with it for a few minutes changing the distance and rotating the remote control in my hand around until it took. The receiver must not be very sensitive so for future reference, a fresh battery, a little positioning distance and angle variations and a little patience should get it done.
Old Dec 30, 2008 | 07:19 AM
clay997tt's Avatar
clay997tt is infamous around these parts
I have a garage door with Genie Intellicode ("the rolling code" garage door). As others have indicated its a little more difficult to program, but I programmed the Homelink buttons in both of my Porsches a few days ago. I found in the Cayenne, I had to hold the remote control foward of the Homelink buttons, almost to the rear view mirror to get the LED to rapidly flash. Then I jumped out of the car, pressed the "learn button" on the garage door opener mounted on the ceiling, hopped back into the car and pressed the Homelink button I wanted to use.
It works like a charm. I did the 911 next. Once I had the technique down, it only took a few minutes to program the 911!
Old Dec 30, 2008 | 09:07 AM
Roller's Avatar
Roller is a splendid one to beholdRoller is a splendid one to beholdRoller is a splendid one to beholdRoller is a splendid one to beholdRoller is a splendid one to beholdRoller is a splendid one to beholdRoller is a splendid one to beholdRoller is a splendid one to behold
Porsche should make garage doors, who wouldn't have one?
Old Dec 30, 2008 | 11:59 AM
Jace's Avatar
Jace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of light
just printed out the instuctions a few posts back I will try AGAIN on the GTS.
I have done it with several of our cars, all with the rolling code, but only the Cayenne gives me problems.
Go figure. I will attempt again, for the 4th time, and probably the 2hr of trying.
Old Jan 1, 2009 | 03:13 PM
cmoore1's Avatar
cmoore1 is infamous around these parts
I think that one thing missing in the owners manual instructions is that the ignition must be on for the buttons in the car to work. I suppose it's to prevent someone from reaching in thru an open window and pressing the button to open the garage door.
Old Jan 1, 2009 | 03:22 PM
Jace's Avatar
got mine setup For some reason whenbi tried setting it up and trying to setup button 3 instead of 1-2-3 in that order it wouldn't work. Once I did it and set it ip 1-2-3 for all doors in that order worked fine. Good riddens
Old Jan 4, 2009 | 06:43 PM
mpatrizio's Avatar
mpatrizio is infamous around these parts
Good info guys. I've been struggling with my homelink as well. I'll apply some of this tomorrow when I try it out.
FWIW, it always works like a charm in my BMWs for some reason.....
Old Feb 8, 2009 | 07:03 PM
Jeff SD's Avatar
Jeff SD is a jewel in the roughJeff SD is a jewel in the roughJeff SD is a jewel in the rough
Originally Posted by alex911s
Download the attached file... never had problems with Cayennes..
Thanks Alex!! Maybe now i can figure out how to program mine.
Old Feb 10, 2009 | 12:54 PM
imcarnuts's Avatar
imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !
Once I figured this out, no problem.
Old Apr 9, 2009 | 07:41 PM
matt-cay-s's Avatar
matt-cay-s is infamous around these parts
at last
Guys....I tried to do this for an hour with no luck! Did my old BMW and Audi Q7 in about 3 mins.....and then read the help here. BUT - I have just done it! I found that you MUST have the remote held VERY close to the main interior light switch - as in 1 inch. if you hold like 3-5" like in owners manual - it does not work!!!!
Old Apr 9, 2009 | 10:10 PM
Kingshawn1234's Avatar
Kingshawn1234 has much to be proud ofKingshawn1234 has much to be proud ofKingshawn1234 has much to be proud ofKingshawn1234 has much to be proud ofKingshawn1234 has much to be proud ofKingshawn1234 has much to be proud ofKingshawn1234 has much to be proud ofKingshawn1234 has much to be proud of
i had that problem too... u need make sure the garage remote is being pointed to where u turn on the lights inside ur car its located right after the garage door opener button in ur car
Old Apr 9, 2009 | 10:12 PM
whoops i just read ur last post and realized u figured it out
Old Apr 10, 2009 | 11:18 PM
Enilder's Avatar
Enilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond repute
Exactly how you should do it except I had another person helping me out.
Old Jan 20, 2010 | 08:39 PM
Bentley Beast's Avatar
Bentley Beast is infamous around these parts
Problem programming Gene Intellicode for Bentley GT
No problem with BMW, Lincoln Nav, but the Bentley seems almost impossible to program. Any suggestions?
