Rotor Alternatives
Old Apr 18, 2008 | 11:11 AM
EMart's Avatar
EMart is infamous around these parts
Rotor Alternatives
Anyone out there not using the factory rotors with the OE brakes? I was going to change the brake pads sometime this spring and I might change the rotors as well. I would like a drilled rotor (just for looks), but it doesn't look like Brembo makes them in the right size (350x34, 330x28).
Here are the ones that I'm looking at so far:
Factory Replacement (Brembo?) from Suncoast (~$400):
http://e-partssales.com/Merchant2/me...Code=955brakes
Zimmermann off eBay (~$600):
http://cgi.ebay.com/ebaymotors/Drill...ayphotohosting
Rotera from Vivid Racing (~$1000):
http://www.vividracing.com/catalog/r...6-p-40456.html
http://www.vividracing.com/catalog/r...6-p-40457.html
http://www.vividracing.com/catalog/r...6-p-40461.html
http://www.vividracing.com/catalog/r...6-p-40462.html
Old Apr 18, 2008 | 01:37 PM
mudman2's Avatar
mudman2 is infamous around these parts
I have Zimmerman on the front, very happy with them especially with Hawk dustless pads
Old Apr 19, 2008 | 09:06 PM
Cannoli's Avatar
Cannoli is infamous around these parts
I just ordered a set last week of front and rear rotors and pads from Zechausen Racing ... http://store.zeckhausen.com/catalog/...88_229_447_449
I decided to go with the StopTech SportStop Slotted Rotors and Hawk HPS pads. I will be cryo treating (www.cryoscience.com) the rotors prior to installation. This will cost about $25 per rotor ... this will increase the life of the rotor between 2 and 3 times of non-cryo treated rotors.
BTW - to remove the rear caliper, a XZN or "Triple Square" 12-point bit (Snap On PN STSM16E ~ $35.00) is required to remove the caliper mounting bolts. And, when performing a brake job (rotors and/or pads), Porsche recommends that you use new hardware - caliper mounting bolts, pad retaining hardware, and brake pad sensors ... for the front and rear, this costs ~ $185.00 with a PCA discount.
Old Apr 21, 2008 | 09:41 AM
vividracing's Avatar
Rotora rotors are great. They actually make alot of OE parts for other manufactures. I have used their big brake kits on many different cars. They are a direct replacement and available in slotted or cross drilled and slotted.
cayguy0521
Cayenne 958
Oct 8, 2015 12:37 PM
Goonie
Sep 12, 2015 02:10 AM
albert@velosdesignwerks
American Muscle Vendor Classifieds
Sep 9, 2015 04:21 PM
Other British Cars
Sep 9, 2015 04:18 PM
