spark plug for V6, $1200?
Old Aug 5, 2008 | 03:01 PM
dabalmury's Avatar
dabalmury is infamous around these parts
i went to dealer for spark plug change, and they quoted me about 1200 for spark plug change only, and about 700 additional for 40k service.
it sounds expensive, is it too much? how much should i expect from an indy shop for spark plug change only?
vehicle is 2006 cayenne v6 with 40,000 miles.
-dabal
Old Aug 5, 2008 | 08:43 PM
cayenned's Avatar
cayenned has a spectacular aura aboutcayenned has a spectacular aura about
way to expensive, get the stuff from suncoast...sponsor on the right, way cheaper and then have an indy shop do it.
Old Aug 5, 2008 | 08:58 PM
SeattleBum's Avatar
SeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud of
-dabal
Sorry man, but if you really even have to ask that question then you must smell like a sucker from miles away... My guess is that your ENTIRE 40k mile service is about $1900. That is pretty expensive as well. I just had the dealership do my 40k service and they charged me almost $1300 for everything...which means I am also a sucker - just not quite as bad.
Old Aug 5, 2008 | 10:41 PM
SoCal955's Avatar
SoCal955 is infamous around these parts
Buy the plugs and do it yourself. A decent indy should charge you $700-$900.
Old Aug 5, 2008 | 11:09 PM
dabalmury's Avatar
yes, indeed, im a sucker. and wow, spark plug change is so expensive.
im picking up my cayenne from the dealership tomorrow, ( had an oil change and inspection), and ill find out what needs to be replaced/fixed from the inspection.
i'll probably take that list to a near indy shop and get serviced there.
BUT, as socal555 mentioned, i want to know how hard is to change spark plugs at home, if i can do it, i'd rather do it home. is it do-able? where can i find some info about 'change spark plugs yourself'?
Old Aug 6, 2008 | 12:09 AM
SeattleBum's Avatar
You know, I must be missing something here. Do you have to pull the whole damn engine to get to the plugs? Are the spark plugs coated in diamonds? This isn't a rear engine layout like a 911 where every servicable item is hidden under body parts. This is a traditional (read: accessible) V6 motor layout, right?
Old Aug 6, 2008 | 10:23 PM
dabalmury's Avatar
very good tutorial, thanks steve,
i'll look for some more info about changing it, and i'll try and see.
but im still a sucker, its very possible that i will probably end up taking my car to an indy shop....
Old Aug 7, 2008 | 12:02 PM
dinorocz's Avatar
dinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond repute
I should move all my shops to the west coast. You guys are getting BUTT RAPED... sucker or not, I could do an engine swap at those prices. HAHAHAHA
Old Aug 8, 2008 | 06:15 PM
SoCal955's Avatar
I meant for the 40K mile service, not the for the plugs.
Old Aug 11, 2008 | 09:04 AM
04CTT's Avatar
04CTT is infamous around these parts
seems crazy to spend that kinda of money on suck an easy job I wonder what an oil change cost 250 dollars lol
Old Oct 18, 2009 | 10:45 PM
stmcleod's Avatar
stmcleod is infamous around these parts
2004 Cayenne turbo spark plug issues
Has anyone done a Cayenne turbo? for spark plugs?
I cant figure out how to get the right cylinder bank done?
Old Oct 21, 2009 | 03:24 AM
1dirtyz's Avatar
1dirtyz is just really nice1dirtyz is just really nice1dirtyz is just really nice1dirtyz is just really nice1dirtyz is just really nice
definatly get the plugs from a sponsor , the dealership here charged $23.5 for EACH spark plug!
Old Oct 22, 2009 | 03:00 PM
Porsche Tech's Avatar
Porsche Tech is just really nicePorsche Tech is just really nicePorsche Tech is just really nicePorsche Tech is just really nice
I assume you mean bank 1-4 passenger side, the one with the torque arm braket? The arm and air pump need to come out of the way, the coil pack cover has to be removed by unscrewing the fasteners and lifting up on the intake manifold side. Then you have to pry up on the part of the cover over cyl 2 and slide the whole cover forward toward the front of the car clearing the torque arm braket. The torque arm bracket over cyl 2 coil has to come off as well. At that point all the coils are right there.
Old Oct 22, 2009 | 03:13 PM
stmcleod's Avatar
thanks, i finally got off last night.. one thing i was told was to use a rag on the coil cap when removing as to not scratch it on the air pump bracket.
Old Oct 22, 2009 | 03:27 PM
Thats exactly the spot. It's kind of shoe horned in there and def easy to scratch the cover on the way out. Soft cloth or wide painters tape works well.
