Rear bumper protective piece fell off...
Old Oct 23, 2008 | 02:34 PM
deputydog95's Avatar
deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !
Has this happened to anyone else yet? It's that little strip on the top of the back bumper. It was on one day, and gone the next. I can't remember what color it was but I think it was black. We have the black out option.
Old Oct 23, 2008 | 02:40 PM
mlc.design's Avatar
mlc.design is infamous around these parts
where was it?
Old Oct 23, 2008 | 03:58 PM
The piece? I have no idea. My service tech asked the same thing. Unfortunately I don't have a chase car following me so I wasn't able to recover it He said I would probably need the piece to get it replaced under warranty.
Old Oct 23, 2008 | 04:34 PM
canberk's Avatar
canberk is infamous around these parts
what piece are we talking about here i couldn't figure out
Old Oct 25, 2008 | 11:32 AM
mlc.design's Avatar
I don't follow either
Old Oct 25, 2008 | 01:01 PM
Jace's Avatar
Jace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of light
the rippled top cover piece is what he is mentioning.
Old Oct 25, 2008 | 01:40 PM
It's not rippled on my base model, but there was a cover on it.
Old Oct 25, 2008 | 01:42 PM
It's hard to tell in the pic, but that piece is white now, not silver like it appears. If you look in the corners you can see some silver poking out. I think that's what it normally looks like if you don't have the factory black out option. Now the adhesive or whatever is left behind and the black cover piece is gone.
Old May 19, 2017 | 05:09 PM
Lightning505's Avatar
Lightning505 is infamous around these parts
957 Rear Bumper Protective Piece Fell Off
I know that this is an old thread, but I have just had the trim piece fall of our '08 957. Note that only the stainless steel cap fell off - it was apparently glued to the part that is attached to the bumper cover. Mine has the same very light gray adhesive showing as in the picture in this thread. I understand that the bracket is attached to the bumper cover with clips, and that the bumper cover has to be removed to replace it. I would like to identify an adhesive that I could use to re-attached the stainless steel part - any ideas? Thanks!
Old May 25, 2017 | 02:57 PM
Domino's Avatar
Domino is infamous around these parts
Best solution is polyurethane based windshield glue. It comes in tubes like silicone.
Old May 25, 2017 | 03:06 PM
Thumbs up Rear Bumper protective piece fell off
Thanks - I'll try the windshield glue
Old Jun 5, 2017 | 06:37 PM
Twinturbofan's Avatar
Twinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud of
On my 08 when I lost the SS cap, simply masked off the white plastic underneath, sanded lightly with 350 grit, followed with 600 grit, blew dust off with compressed air and then wiped down with degreaser. A number of light coats with a rattle can of gloss black turned out perfectly.
Old Jun 6, 2017 | 08:26 AM
Thanks for the guidance! But, given that I have a dog that jumps in and out of the hatch, I think I need the stainless steel surface rather than a painted one.
Old Jun 6, 2017 | 09:03 AM
Understood and makes sense. One other option is plasti dip. It goes on like spray paint but drys like a rubberized finish. If you put it on and it didn't hold up or you didn't like it, it peels right off. Maybe a temporary solution, but I agree not nearly as good as a proper fix.
Mackchacha
Jul 9, 2019 11:03 AM
awdbiturbo1
Feb 18, 2016 10:24 AM
gulf gt
Aug 27, 2015 10:27 AM
TrackOne
Aug 20, 2015 12:56 PM
albert@velosdesignwerks
BMW //M
Aug 20, 2015 07:12 AM
