How do you Activate TPMS
Old May 20, 2009 | 08:08 AM
westport's Avatar
westport is infamous around these parts
TPMS sensors are not that expensive. I believe they are attached to the tire valves. There is a good chance your car has the system, but the sensors are not installed. I am not sure how you will get rid of the error message though. As far as target tire pressures ,... there is a really good service only dealer in Danbury,CT called Farnbacher Loles. They are really good. They will give you the right answer. 203.798.2929 ask for Robin. She knows everything there is to know about tires and wheels for Porschess. You might as well ask her for a quote to install the TPMS sensors too.
Old May 21, 2009 | 04:09 AM
MTRX's Avatar
MTRX is infamous around these parts
Originally Posted by westport
Sensors replaced. The TPMS is working! This leads me to a new question. They set the tire pressure on the front tires to 37 and the rears to 46. This seems strange to me. I have 20" Pirrelli Scorpion Ice and snow tires. Does anyone know if this is correct?
Tire pressure usually depends on the tire manufacture i think. You should have some numbers on your tires. If your wheels are all the same size I don't see why they would have a different pressure on the front.. seems strange.
C5tt
Oct 24, 2015 07:35 PM
slicky rick
Oct 23, 2015 06:53 PM
Fullthrottleguy
Sep 28, 2015 03:19 PM
Sep 28, 2015 02:19 PM
