V6 gearbox
Old Nov 18, 2008 | 08:33 AM
ruzz1's Avatar
ruzz1 is infamous around these parts
V6 gearbox
is there a common problem with the v6 gearbox? i find it a bit rough when decelaration, i.e when downshifting. mine has only done 30k kms.
Old Nov 18, 2008 | 09:16 PM
mlc.design's Avatar
mlc.design is infamous around these parts
there was a recall on the transmission control mod
Old Nov 19, 2008 | 11:14 AM
Triple B's Avatar
Triple B is infamous around these parts
I do not know if it is a common problem……but on our 05 V6 we had a problem with down shifting. At first it was just a harder than normal down shift under easy breaking. Then it became a violent 5th to 2nd down shift…..
At first the dealer would not do anything because I did not have “N” rated tires. No big deal we were getting close to needing a new set of tires anyway. After we installed the new approved tires the problem became worse. We had to drive with the PSM off until I could get to the dealer.
The dealer changed the transmission shift module, re-programmed the traction control and service trans all under warranty.
We have not had any problems since then.
Good luck
Old Nov 24, 2008 | 04:05 PM
onemanclique's Avatar
onemanclique is infamous around these parts
Do you know if the '08s have the same issue?
Mine does have a jerk when it downshifts but nothing too violent but noticeable. I JUST (two days ago) swapped my tires for an allseason set which aren't n-rated. I'm sure my dealer will give me the same run around not wanting to do any work on it until I get new tires.
SlinginHoss
11
Oct 8, 2025 05:16 PM
mxracer
Jun 23, 2018 06:27 AM
embdenb
Sep 30, 2015 09:27 AM
pwdrhound
Sep 25, 2015 05:25 PM
