wanted to replace some of the exterior bulbs, info?
Old Nov 20, 2008 | 12:47 PM
Jace's Avatar
Jace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of light
So a few things I am thinking of.....
replacing the front two cornering lights to a brighter bulb.... LED whiter light or something.... any suggestions?
Also, is there a brighter LED or something to replace the backup reverse light?
Also, the lights under the side mirrors... is there a brighter bulb or replacement to chance these out?
Old Nov 23, 2008 | 07:17 PM
Skr4tCH's Avatar
Skr4tCH is a jewel in the roughSkr4tCH is a jewel in the roughSkr4tCH is a jewel in the roughSkr4tCH is a jewel in the rough
you want do it all yourself? since you can just give it to any tuning shop and they'll do whats needed
Old Nov 23, 2008 | 08:49 PM
Jace's Avatar
why take it somewhere to do something I'd enjoy doing? Uh ok
So any suggestions besides that?
Old Nov 23, 2008 | 08:56 PM
Skr4tCH's Avatar
Yea give me an hour i'll go take apart my cayenne.. and will tell you
My first thoughts.. increase voltage or different bulbs.. will know in like one hour.. so if you'll wait i'll let you know
Old Nov 23, 2008 | 09:18 PM
canberk's Avatar
canberk is infamous around these parts
replace all the lights that you're talking about with xenons
Old Nov 23, 2008 | 09:54 PM
Jace's Avatar
missing the point all.
What is a good led compamy that sells? I know the type of bulbs via the manual I was thinking of changingost to led.
Old Nov 24, 2008 | 01:36 PM
sparkhill's Avatar
sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !
There are a couple of problems with changing the bulbs. The silver or blue coated bulbs get about as hot as the sun and have been known to melt bulb sockets, wiring, housing, etc. The LED's frequently have substantially lower resistance compared to the stock bulb triggering the "replace bulb" warning on the dash. In the end, it is pretty hard to find many good, safe, options.
Old Jun 19, 2009 | 02:40 PM
Bruin Pcar's Avatar
Bruin Pcar is infamous around these parts
Resurrecting this post...
Hey Jace and company,
Sorry about digging up a post from late last year, but figured this would be the best route to go...
Has anyone found any solid options to replace some of the lights on our Cayennes so we can get a closer match to the HIDs without faults codes, melted harnesses and houses, etc??? I switched the rear license plate bulbs to a xenonmatch color, and it looks clean. Looking to the do the same for a few other bulbs...
- Puddle/Side Mirror Lights
- Static Front Cornering Lights
- High Beam Lights
Experiences, bulb info, pics and/or DIY instructions would be greatly appreciated.
On another note, I had the dealer drop in some chromium lights for the clear sidemarkers on my GTS this AM (since they were taking the wheels off for rotation and alignment, and dropped in yellow fogs), but later got a call from the advisor and tech stating that the temperature difference was more noticeable than I thought it would be (sparkhill, this confirms that they run hotter). Decided to switch to the stock amber lights with clear lens just to be safe...
Old Jun 22, 2009 | 10:31 PM
dtran023's Avatar
dtran023 is infamous around these parts
I'm interested in the LED lights also, I changed out the licence plate lights to 6418 type LED and its working fine without throwing me any error light. I seriously doubt that the dash will through any error lights if you change out exterior lights (side mirror lights or fornt cornering lights).
Old Oct 3, 2009 | 02:58 PM
dtran023's Avatar
Jace,
What is the status on your lighting mod? thanks.
Old Oct 12, 2009 | 05:17 PM
Z_GTS's Avatar
Z_GTS is infamous around these parts
im trying to do the same thing
Old Oct 16, 2009 | 03:00 PM
akshon's Avatar
akshon is infamous around these parts
guys i have done this
The company name is Hoen
you need the following three bulbs
Fog Lights : H11 xenonmatch.
License plate: C5W dLED,
Side Markers: W5W dLED_2
only exterior light I havent figured out yet is the small light under the mirror.
Old Oct 17, 2009 | 04:16 PM
epicjon's Avatar
epicjon is infamous around these parts
Raybrig is the cleanest and brightest
Old Oct 18, 2009 | 09:30 PM
eVoMotion's Avatar
eVoMotion has a brilliant futureeVoMotion has a brilliant futureeVoMotion has a brilliant futureeVoMotion has a brilliant futureeVoMotion has a brilliant futureeVoMotion has a brilliant futureeVoMotion has a brilliant futureeVoMotion has a brilliant futureeVoMotion has a brilliant futureeVoMotion has a brilliant futureeVoMotion has a brilliant future
I need that under mirror light as well. dang.
Old Jun 30, 2010 | 09:13 AM
freshlysqueezed's Avatar
freshlysqueezed is infamous around these parts
Hey Guys,
Im new to the forum and have been reading on threads. I just bought my CTT a month a go and been tinkering around with my 06' CTT to change my original lights to LED ones and I have found some answers to some questions.
- How to change side mirror 'puddle lights' ?
The side mirror 'puddle lights' are easy to change. First make sure ur current setting is saved with ur seat memory. Push any one corner of the mirror in and then with the one corner sticking out, gently pull on it a bit and it should pop right off. There is no clips or anything holding it in, so do not worry about breaking anything, just be gentle. There are wires attached to the mirror that you pulled off, so let it rest. Inside near the bottom you can see where the light is. Just pull the socket to the left (if your working on the driver side mirror, vice versa for the other one) and then you should see the bulb in the socket. The bulb is W5W, any led bulb with the same connections on the bottom of the original bulb should work, and make sure the LED is pointing down and not straight ahead, if you want a good light, since the bulb is pointing sideways and not down.
- Where to buy LEDs?
I bought mine from store.ijdmtoy.com. They ship via USPS, so it is good for USA customers. I am in Calgary, Alberta, Canada, so it takes longer than usual. The lights are really good and bright, you can also filter bulbs that dont affect OBCs of European cars (BMW, Mercedes, Porsche, etc.). This is also where I got my license plate bulbs.
- How to change Static Front Cornering Lights?
In your manual there is a step by step guide on removing the headlight. It is very **** easy and very easy to do. I changed my lights in no time, I am not sure if I should go into detail, but if anyone needs help just PM me. The bulbs I ordered for the cornering lights are H3 LEDS from store.ijdmtoy.com. I am like 90% sure any bulb being replaced in the headlight wont trigger any OBC errors, but I will let you all know when I have installed the H3s. So, far I have installed DRL LEDs and they work with no OBC error and matches my headlights, so I am sure the H3s should be ok.
- How to change license plate light?
I ordered the lights from store.ijdmtoy.com, they were in the Audi, Porsche, Volkswagen section under Automaker. I have yet to receive these bulbs, so I will also let you all know how they are with the OBCs. To change them, simply grab the appropriate head screwdriver, unscrew the light housing. Pull out the housing, press the tabs where the wire connects to the house to pop it off. Pop off the lenses and then change the bulbs.
This is what I have done so far with my Cayenne and I hope this helps. I apologize for no pictures on the steps I have done. However, if anyone has a question just shoot me a PM. This is a sweet forum and I do plan on staying and visiting daily!
Cheers,
Thompson
