DIY : Installing OEM Hitch and Wiring
Old Dec 13, 2017 | 01:57 AM
  #31
Mattias's Avatar
Mattias is infamous around these parts
Thanks!
Old Dec 13, 2017 | 07:32 AM
  #32
porschetech's Avatar
porschetech is infamous around these parts
don't forget vehicle has to be coded if you're installing the control unit
Old Sep 13, 2018 | 05:07 AM
  #33
Phoenix0917's Avatar
Phoenix0917 is infamous around these parts
I know this is a few years old but I am about to do this and was wondering about the bolts. With the OEM hitch do I need to order new bolts or will the ones already in there work? My Cayenne is a 2009 S. I have everything minus these bolts and the wiring harness (OEM). I have not been able to fine one under $250 yet so if anyone has a used one for sale let me know please.
Todd
Old Dec 5, 2018 | 02:53 PM
  #34
Don hitchman's Avatar
Don hitchman is infamous around these parts
Not clear
Originally Posted by CBRacerX
I may have found the holy grail of install manuals. This attachment includes ALL the instructions you need in one document, including how to remove the bumper, how to remove the interior trim and so on. All the other instructions I have found refer you to other procedures (which you may not have access to).
Bonus, it is in English and Deutch.
I have that PDF file which I printed out. Most of the instructions are good, but when you get to the part that describes how to hook up the control module it's really vague. It would seem that there should be an extra pigtail in that area on the vehicle harness that plugs into the module. The oem retrofit kit included the wiring harness that attached to the hitch. It only has one plug into the module and the other one goes into the vehicle harness behind the taillight. I had the help of my local body shop owner to do the actual installation but neither of us could find the other plug for the control module!!
I know that the dealership has to plug into the main computer and program it for the extra functions, but it makes no sense to me that we can't find the other plug and the trailer plug-in has no power to it.
The proper fuses installed.
Old Apr 20, 2021 | 04:30 AM
  #35
Elvis01's Avatar
Elvis01 is infamous around these parts
Help
Originally Posted by Lclark
Did you figure it out rod? I can let you know if you are still stuck.
Hi new to this but can you help with wiring on my cayenne,trailer hitch all the wiring are driffent to nomal, do you know which one are for what
Old Apr 20, 2021 | 06:49 AM
  #36
Oem hitch install
the pigtail you are looking for is located over the wheel well. It is easy to miss because it is wrapped in foam, which is typical if porsche...they do this to prevent rattles.
Also, if you are planning on using a brake controller, then you have to visit an automobile electric shop for that...porsche dealership will not install the brake controller due to liability issues, but they will refer you to a local shop that will do t he controller install.
dgreen78
Nov 22, 2017 04:08 PM
Ken968
Cayenne 958
Aug 30, 2017 04:31 PM
Bap0009
Cayenne 955/957
Aug 22, 2017 07:24 PM
cellg8
Cayenne 955/957
15
Dec 22, 2007 09:56 AM
