Michelin Diamaris noisy?
Old Oct 2, 2004 | 04:16 AM
DEETZ's Avatar
GO 6SPEED!
DEETZ is infamous around these parts
There is a major noise from the tires, I am running 285/35/22 and it is alot noisier than my stock tires(Turanza)
Kevin.M: does it happen to you? I am running 43psi front and 45psi rear... what about you?
Does anyone know whether it is supposed to be that noisy?
Old Oct 2, 2004 | 05:07 AM
offroad911's Avatar
offroad911 is infamous around these parts
Deetz, The 22" has much lower profile and less rubber to cushion. You will always here more noise out of lower profile tires. You think it is bad now, just wait til you get 2,500 to 5,000 miles, then you will hear noise!
Old Oct 2, 2004 | 05:21 AM
psychoflex's Avatar
psychoflex is infamous around these parts
Deetz,
Are 285's the widest you can go with 22"s without them extending past the fenders?
Old Oct 2, 2004 | 05:37 AM
damon@tirerack's Avatar
Moderator
Look at the tires you bought:
http://www.tirerack.com/tires/tires....l=4X4+Diamaris
Vs. the ones you had:
http://www.tirerack.com/tires/tires....l=Turanza+ER30
A directional tire (the Michelin) will be noisier than a circumfirential tire (The BStone) because the tread runs against the direction of the tire, and not with it. A directional tire's tread "slaps" the ground, especially as they wear.
We don't find that many people complain of the noise of the Michelin. But the tire is awfully wide. And a wide, low profile tire will become more noisy as they wear.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Oct 2, 2004 | 07:55 AM
ESK's Avatar
ESK
Hick from NH
ESK is infamous around these parts
Originally posted by damon@tirerack
And a wide, low profile tire will become more noisy as they wear. [/B]
The Michelins are not bad in the beginning, but after around 6,000 miles or so you really start to notice the tire noise.
Old Oct 2, 2004 | 09:13 AM
DEETZ's Avatar
GO 6SPEED!
295/30/22 you can get with 22x10 wheels... bigger than that will stick out
I am hearing something noisy, what else can it be besides the tires?
I used to run 295/30/22 on my x5 with pirelli scorpion zero and it was not as loud as this... I need some help here, any ideas?
Old Oct 2, 2004 | 09:57 AM
psychoflex's Avatar
Thanks! I think I'm going with 22" black Techarts with a silver outer lip. Why'd you switch from the scorpions?
Old Oct 2, 2004 | 01:40 PM
DEETZ's Avatar
GO 6SPEED!
I have to run 285 because my wheels are not 10.0 but they are 9.5
Old Oct 4, 2004 | 09:47 PM
psychoflex's Avatar
Deetz,
Why did you go with 9.5 instead of 10 on your rims? They look awesome!!
Old Oct 4, 2004 | 11:38 PM
DEETZ's Avatar
GO 6SPEED!
thanks, they can't make 10 due to the part problem. I have asked 100000 times so you don't have to bother. In order to clear the big brakes, you can only have 2" lip and you can go either with 9.5 or 10.5. Personally I prefer 9.5" because it doesnt stick out as you can see from the picture. 10.5" does look better but it will stick out by 0.25"
Old Oct 4, 2004 | 11:49 PM
psychoflex's Avatar
Thanks, Deetz. You saved me a phone call!
Old Oct 5, 2004 | 01:51 AM
psychoflex's Avatar
Deetz,
If I were to get the 10.5", could I have a bigger lip on the rims?
I think black rims only look good with a wider silver lip. What is the part problem that you were referring to? thanks again.
Old Oct 5, 2004 | 01:52 AM
psychoflex's Avatar
Oh, I forgot. What about reverse rims for a bigger offset? Any problem clearing the brakes with 22"X10 or 10.5?
Old Oct 5, 2004 | 06:57 AM
DEETZ's Avatar
GO 6SPEED!
they don't make 22x10 for the Cayenne. If you get 10.5", you can have 3" lip
try to ask Mr Wheelexperts (Peter) or Mr LucentMotors (Arling) they will explain it to you ^^ you should get it from them too
away
Apr 27, 2016 03:53 AM
sdg1871
Nov 22, 2015 07:27 PM
Wheel Experts
Oct 6, 2015 09:19 AM
rob4wellness
Oct 2, 2015 07:32 AM
Wheel Experts
Wheels/Tires
Sep 29, 2015 09:45 AM
