Pollen Filter Change Procedure - 2004-2007
Rating: Thread Rating: 2 votes, 5.00 average.
Old May 12, 2009 | 05:54 AM
Vyper340's Avatar
Vyper340 has a spectacular aura aboutVyper340 has a spectacular aura aboutVyper340 has a spectacular aura about
I've searched but cannot seem to find anything on the process for changing the cabin air filter on Cayenne's. Does anyone have the link or can they explain the process?
Thanks!
Old Apr 13, 2011 | 09:16 AM
spinny02's Avatar
spinny02 is infamous around these parts
bump
Old Apr 13, 2011 | 01:12 PM
taddyangle's Avatar
taddyangle is infamous around these parts
Try pelican. I bought one from them a few weeks back. It takes about 10 to change. I saw a DIY, but can't recall where.
In any case, it is two t-hex (I think that is what they are called) remove those and then filter slides down. Make sure when u remove u replace same way, because there is an air flow arrow on filter. You will see an arrow on side of filter.
The directions that came in filter box were not correct so look for DIY. I think it was on pelican or reenlist websites.
Old Apr 14, 2011 | 10:34 AM
FastHackem's Avatar
FastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud of
Look under the passenger side dash and remove the black shroud with a phillips screwdriver:
Then take a 5.5mm wratchet and remove two hex head bolts from the filter access:
Remove the cover and then pull out the old filter:
Here is the access cover and my old filter:
Old VS New:
Slip the new one in there with the arrows on the filter pointing toward the center dash. The rest is reverse procedure of removal. ENJOY!!!
Old Apr 16, 2011 | 01:19 PM
FastHackem's Avatar
***Please add reputation if you found this thread helpful to your cabin filter change***
Thanks,
Scott
Old Jun 25, 2011 | 02:34 PM
royota's Avatar
royota is infamous around these parts
Great! I needed that too.
Old Jun 25, 2011 | 03:18 PM
deilenberger's Avatar
deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !
Actually - perhaps things have changed. The screw under the dash on my '06 is a Torx-10 (AKA T10).. and the only place I could find a 5.5mm socket was AutoZone (although it's claimed to be available at Sears also..) It was about $4 at AutoZone.
Oh - also - the part of the housing that dips down just to the right of the filter drawer is the drain for the HVAC condensate. Since you can easily see all the crap that builds up on the filter, it's worth wiggling your hand into the opening whilst the filter is out and remove any debris you find.
Old Jun 27, 2011 | 06:58 AM
zzzx's Avatar
zzzx is infamous around these parts
I did not use the 5.5mm socket, try the standard ones. there was one that fit fine just not as snug as the 5.5mm one. but it works
Old Sep 22, 2013 | 03:15 PM
Wecnside's Avatar
Wecnside is infamous around these parts
Great help. Thanks
Just changed the filter on my new-to-me 2003 955 CTT.
It is a torx screw on mine, not Phillips. I had a 5.5mm socket in my standard set from Sears. Always wondered what that one was in there for!
One additional note is to detach the plug in for the under dash light to release the whole panel down. Self evident to most, might be helpful tip to some.
Total "project" time was 10 minutes.
Now my air is fresh and clean. Thanks again!
CoreyC2S
Nov 18, 2017 12:13 PM
SharkyShark20
Sep 19, 2015 09:54 PM
away
Sep 4, 2015 12:30 PM
00aston
Aug 27, 2015 12:01 AM
ECS Tuning - BMW
Aug 19, 2015 09:29 AM
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
