How to pull ECU??
Old Jun 16, 2009 | 09:35 PM
mrdstr's Avatar
mrdstr is infamous around these parts
How to pull ECU??
I'd like to pull the ECU and send it out for tuning. Anyone have a how to? I got discouraged at simply disconnecting the battery (there are 2?!) I found the ECU, but can't decide how best to access it. Do you pull the fender liner? Or go from the top? How is it held in? TIA
Old Jun 16, 2009 | 09:49 PM
sharkster's Avatar
Once the battery is disconnected your ECU is in the front passenger side in the back corner of the engine. There are three screws to loosen and it pulls/slides out... If you want call the shop tomorrow and we can explain it.
Old Jun 16, 2009 | 10:23 PM
roxboxxx's Avatar
roxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant future
Mrdstr - Maybe your like me and already researched this to death, but if not; you can flash it remotely with the softronic kit and a laptop. Not sure what your ride is - so this is the link for the Cayenne S.
http://www.vividracing.com/catalog/s...8-p-25312.html
Old Jun 16, 2009 | 11:31 PM
super996TT's Avatar
super996TT is infamous around these parts
Facing the car: open the hood, walk to the left hand side far corner by the windshield. There is a black plastic cover with 3 fillips plastic clips. Remove that cover and there is the ECU. It is held on by 2 clips. I would buy 2 new clips since I broke both trying to reinstall the ECU. Good luck!
Old Jun 17, 2009 | 05:18 PM
mrdstr's Avatar
so only disconnect the battery under the seat? Can this be done without pulling the seat bolts?
Old Jun 17, 2009 | 07:01 PM
Softronic's Avatar
Veteran: Marine Corps
Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !
Hello,
I'm not sure who you have to send the DME to however most tuners should be able to flash this for you in the car.
Best,
Scott
BLKMGK
May 31, 2016 04:32 AM
BonitaBeast
Cayenne 955/957
11
Oct 16, 2015 06:14 PM
Arizona
Sep 17, 2015 01:45 PM
996 Turbo Vendor Classifieds
Sep 17, 2015 01:41 PM
Yogi911
Sep 9, 2015 08:20 PM
