Looking to change my D1S Xenons on my '09 GTS - Any Suggestions on how???
I simply want to replace the OEM bulb with a 6,000K or 8,000K bulb. I have a spare set of Philips D1S bulbs that I would like to try.
Can someone please tell me how to access the bulbs? Is this difficult? I've read another post that it takes on 15 mins, but no instructions were given.
Any help would be greatly appreciated!
Along the same lines....if any of you have any directions on how to access the fog lamp bulbs, I'd like to change those too. I believe they're H11's. Can someone confirm?
Thanks!
Thanks!
Okay, I feel like a moron! I just got my GTS on Friday, and I've been too busy driving it to have time to read through the manual.
I'll check that out this week....hope the instructions are straight forward.
instructions are in the manual for headlight. there is a removal tool in trunk. fairly easy after first time
fogs are a PIA and easiest way to access is from front wheel wells. my 05 CTT fog bulbs are H11. check manual to make sure they are the same but i doubt they have changed
i would swap to 6000k
8000k is to ricey and you loose light output
pshep138
Sep 1, 2015 09:45 AM
LiquidElephant
Aug 27, 2015 06:17 PM
