Techart lowering module
Old Aug 9, 2009 | 06:02 PM
acasshmoney's Avatar
acasshmoney is infamous around these parts
I have a few questions about the techart lowering module...
1-does it go lower then the lowest setting on the air suspention options or does it keep it at the loading level all times..
2-how much does it cost?
3-anybody have pics of this with the stock GTS rims if so let me no
4-are there any other lowering modules that are cheaper and actually make the car go lower then loading level...
thanks
Old Aug 9, 2009 | 09:49 PM
alex911s's Avatar
alex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond repute
1) you can drive to loading level.. once you remove the key it will go lower than
loading level automatic.. the off road level is also a bit higher..
2) $2000-$3000 depending on the retailer.. need to be calibrated by a porsche dealer
3) i believe renntech is the cheapest ..
Old Aug 10, 2009 | 01:19 AM
so after all is said and done how much am i looking at and sorry if this is a dumb question wat does calibrated by the dealership mean ?
Old Aug 10, 2009 | 02:55 AM
ONE234's Avatar
ONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud of
you have to go to your OPC (dealer) so he can program/code the module to your car, basicly so the car knows you have the module fitted.
otherwise it wont recognise the hardware. its because of the canbus system.
everytime you add an electrical option, the car needs to be "syncronised/linked" together.
you can use an indipendant centre if they have an autologic or PIWS set up.
good luck.
Old Aug 10, 2009 | 10:35 AM
Thanks if there are any other ones out there let me no thanks
Old Aug 10, 2009 | 11:22 AM
Jeff SD's Avatar
Jeff SD is a jewel in the roughJeff SD is a jewel in the roughJeff SD is a jewel in the rough
Call CEC in Beverly Hills. They'll take good care of you!
I love my TA module!
Old Aug 11, 2009 | 09:51 AM
RE5PEKT's Avatar
RE5PEKT is infamous around these parts
TechArt Lowering Module is really a great piece. It lowers driving and loading mode. Raises off-road mode. Automatic parking drop to loading mode.
Call Alex at TAG Motorsports in San Diego - Hell give you a great deal
Old Aug 11, 2009 | 03:46 PM
SeattleBum's Avatar
SeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud of
Actually, mine only allows me to drive in "Low" setting (one setting below NORMAL). If you put it into the "Loading" setting at a stoplight it will just raise back up once you go over a few mphs.
Old Aug 11, 2009 | 09:04 PM
Jeff SD's Avatar
Me too. The TA module will not permit you to drive in loading mode.
Old Aug 12, 2009 | 04:43 AM
ONE234's Avatar
i have the lowering module also, but my friend does not (cayenne S) but when we are out together (he has air suspension also) at traffic lights he lowers the car to "loading level" and when he drives off, it automaticly rases up to "low level" looks very cool, and to be honist is the same as a lowering module...but is just manual
you can do this by hand everytime if you want to save $2-3000
Old Aug 12, 2009 | 08:28 AM
GMP Performance's Avatar
Site Sponsor
Renntechs even with their remote is about 2k which is 1k less than the Techart one. Techart makes great stuff but they are expensive, mostly because of the exchange rate and duties but this is the world we live in.
adnanm3
Nov 22, 2023 02:43 AM
NC 996TT
Mar 23, 2023 06:19 AM
Fieldsport
Dec 2, 2015 06:31 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
kensworth
Cayenne 955/957
Sep 9, 2015 05:45 AM
