Installed Turbo cluster
Old Aug 26, 2009 | 10:38 AM
Twincharge's Avatar
Twincharge is infamous around these parts
Originally Posted by ONE234
quality should not be an issue as they state they supply to manufactures and as there german i would say this is a pre requisite?
my colleague has ordered a set in white, so when they arrive i will have a peep at them (proberly have to fit them for him )
so if you can wait 2/3 days ill let you know.
Use this Gemballa doc as a guide to swap the dials.
Before you remove the cluster from the vehicle make a note of the needle rest positions with a camera. When removing needles simply twist anti-clockwise and lift, luckily the Cayenne is pretty easy to work with.
When replacing needles, place cluster (without front glass) in vehicle connected to force cluster to 'reset' needles so you can correctly determine rest positions are correct for each needle.
To force another reset simply disconnect and reconnect.
Be careful to not leave ignition on whilst disconnecting cluster or you will fire up an airbag fault code.
File Type: pdf
Old Aug 26, 2009 | 11:20 AM
madburg's Avatar
madburg is infamous around these parts
Sounds good, we'll watch the forum for your update on your friends car.
As for "they are german" I am sure every country has there con-artist's/low grade manufacturers, etc...
Do they have a web site or only sell via e-bay (if you know)?
Old Aug 26, 2009 | 04:21 PM
ONE234's Avatar
ONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud of
i fully understand your concerns, but i would say there listing on ebay is one of the most comprehensive i have ever seen, it lists everything you would need to know regarding manufacture references and build quality, what more could you ask for?
if your unsure wait for my report or dont buy. i bet the gambella ones are made by them.....
you have to trust sometimes, and its not a lot of money after all.
good luck
Old Aug 27, 2009 | 07:10 AM
madburg's Avatar
Hey ONE234,
It is just that, a concern. Look forward on your report. I personally am in no rush. I have a 06 TTS and just looking to change the color at some point to my interior color.
Can you post the seller you are dealing with, would like to make sure I am on the same page as what you are looking at.
They maybe producing for gambella and others, someone definitely is... but usually those manufactures don’t sell outside of their network.
Old Aug 27, 2009 | 07:23 AM
ONE234's Avatar
Old Aug 27, 2009 | 11:49 AM
ONE234's Avatar
dont ask me how...but my friend has got hold of 2 sets of these white dials with grey numbers, for a cayenne turbo in MPH
they are as the advert and brand new, he wants £150 including shipping.
ready to go.(usa + £10)
im sorry if this is in the wrong place, mods please move if ive transgressed.
Old Aug 27, 2009 | 03:07 PM
madburg's Avatar
Throw a few pictures up of it, please
Mackchacha
Jul 9, 2019 11:03 AM
TrackOne
Aug 20, 2015 12:56 PM
turbosonoma
Aug 19, 2015 02:05 PM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
