Confused about rotor sizes
Old Sep 22, 2009 | 08:09 AM
strife_wy's Avatar
strife_wy has a spectacular aura aboutstrife_wy has a spectacular aura about
I have an '06 Cayenne S (955) and need to replace all four rotors.
I understand that there are two front rotor sizes - 350mm and 330mm.
Is there a rule of thumb around which rotor size is on my car? Do all Turbo's and S' have the 350mm?
Thanks in advance
Old Sep 22, 2009 | 08:32 AM
NorthVan's Avatar
Strife,
If you are looking for a good brake package for a great deal, this guy sells a lot to the Touareg guys, and he also sells the kits for the Cayenne's. I think that the brakes on my Egg are the same as on your Pepper.
I don't have any affiliation with him other then his brakes are on my Touareg now.
http://www.alretta.com/
Old Sep 22, 2009 | 08:41 AM
iJeremy's Avatar
iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !
Do you have Red or Black calipers?... Most S's have RED - If so you need the larger diameter.
If by the off chance you have the SILVER finish, you also need the larger of the two.
Old Sep 22, 2009 | 03:41 PM
strife_wy's Avatar
Originally Posted by NorthVan997C2S
Strife,
Thanks NorthVan - I'll check them out!
Old Sep 22, 2009 | 03:42 PM
strife_wy's Avatar
I have silver calipers... which is too bad... I didn't know most S' have red calipers
So silver = 350mm as well?
Old Sep 22, 2009 | 03:50 PM
NorthVan's Avatar
You can give Geoff a call, he could answer a lot of questions very quickly.
Old Sep 22, 2009 | 03:53 PM
strife_wy's Avatar
Sounds good... do you know if they carry non-OEM rotors and pads?
I'm really interested in a set of Zimmerman cross drilled rotors and Hawk HPS pads... the OEM brake dust is killing me!
Old Sep 22, 2009 | 08:12 PM
ClutchnThrottle's Avatar
ClutchnThrottle is infamous around these parts
This is from the Rennlist site on the DIY for the front brake rotors.
"Due to manufacturing differences we have seen, you must determine the size of the rotors on your vehicle prior to ordering. The easiest way to figure out your brake size (other than actually measuring the diameter of your rotors) is to look at the caliper. It should have "17ZR" or "18ZR" cast into the body. 17ZR=330mm (black caliper), 18ZR=350mm (red caliper). You can probably see this with the wheel mounted to the vehicle, but you may have to remove the wheel - but it's much less trouble (and cheaper) than returning a set of incorrect rotors/pads."
Here is the DIY
Brake Job
I have a CS with silver calipers. I have the 18RZ caliper. The "18RZ" is cast right on top of the caliper. If you look at the third picture down, you will see the 18ZR casting on the caliper.
I just did the rears yesterday. Very simple. I stayed with OEM. I know its alot of brake dust. When the wheels get dirty, its time to wash the CS.
Enjoy!
Old Sep 22, 2009 | 10:04 PM
porschespeeddemon's Avatar
porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !
Here are the caliper colors/rotor sizes for fronts
V6/Black Caliper:330mm
V8/Silver Caliper:350mm
V8TT/Red Caliper:350mm
V8TTS/BIG Red Caliper:380mm
Old Sep 23, 2009 | 08:45 PM
strife_wy's Avatar
thanks everyone!
Old Feb 29, 2012 | 06:16 AM
intheflesh's Avatar
intheflesh has a spectacular aura aboutintheflesh has a spectacular aura aboutintheflesh has a spectacular aura about
Sorry for bumping an old thread. What about rear rotors?
I have an 06' s titanium with silver calipers
Old Dec 18, 2019 | 09:47 AM
Lov2bugu's Avatar
Lov2bugu is infamous around these parts
What about the rear?
Old Feb 5, 2020 | 05:13 PM
Dave_S's Avatar
Dave_S is infamous around these parts
The threads old but just for those looking here.... you can find it on your build codes sticker in the spare wheel compartment. There is another option for the TT, Porsche build code1LP = 18+ brakes they are the biggest to fit 18" wheels at 368mm and they are thicker at 36mm.
Jul 29, 2019 11:13 AM
ModBargains
Audi Vendor Classifieds
Sep 1, 2015 05:26 PM
awchristler
Bentley
Aug 24, 2015 03:53 PM
TrackOne
Aug 20, 2015 12:56 PM
ModBargains
Aug 20, 2015 12:28 PM
